Storage Screws for mounting M.2 on Asus B250M Plus
Discussion in 'Hardware' started by Arboreal, 10 May 2018.
  1. Arboreal
    Arboreal Well-Known Member
    21 Jan 2011
    Just got my new board up & running but it's missing the spacer nut and screw to mount an M.2 drive on the board.
    It's an Asus Prime B250M Plus as linked
    At the moment, I have it held down with a loop of cotton...
    These look hard to find and seem $$$ on ebay.
    Anyone know what thread/pitch the screws are? I could get a long one and make a spacer myself
  2. Xlog
    Xlog Active Member
    16 Dec 2006
    Most likely M2 (as in ISO 2mm).
  3. Big Elf
    23 Apr 2009
    A bit of googling suggests M2 x 3mm
  4. Arboreal
    21 Jan 2011
    Thanks guys, didn't get far at work on it.
    M2 for an M.2, how apposite! :grin:
    I'll get some tomorrow on my travels, cheers
  5. BeauchN
    BeauchN Active Member
    5 Apr 2011
    If it's helpful I can bung you a couple in the post? I'm sure I've a few laying around.
  6. Arboreal
    21 Jan 2011
    Thanks N, that's very kind of you. These mounts are not the usual height for some reason, about 6mm off the deck, so the normal screws don't reach.
    Let me see how I get on today at the hardware shop, and I'll update later
