Windows script error w10
Discussion in 'Software' started by nichos, 24 Sep 2015.
  1. nichos
    nichos Minimodder
    17 Feb 2006
    Why suddenly " Script Error " appears continuously when I try to close an IE page? asking to choose "use script Yes or NO". & either clicked gives an blank page & have difficulty closing it.
    I tried Tools>Advanced & "disable script errors" is ticked. I cleared it, reopened IE, re-ticked it with no difference.
    Can anybody help?
  2. nichos
    nichos Minimodder
    17 Feb 2006
    SOLVED
    In Tools>Int.Options>advanced & at the bottom I clicked Reset
  3. nichos
    nichos Minimodder
    17 Feb 2006
    NOT Solved,
    Yes tried it, went away for a while & now is back
    The Script Error came back in vengeance
