scsi adaptor
Discussion in 'Hardware' started by Ln2OC, 30 May 2005.
  1. Ln2OC
    Ln2OC What's a Dremel?
    6 Dec 2004
    Hi
    I have a scsi hdd that I wat to hook up to my new rig, unfortunatly my new mobo doesnt have a scsi port :waah: , is it possible to buy/make a scsi adaptor? Is there a pci scsi card available that would work with a hdd?
    Any advise would be great
    Ln2
  2. Hiren
    Hiren mind control Moderator
    15 May 2002
    There are many many PCI scsi cards out there. Adaptec make good ones, try e-bay to avoid paying huge amounts for a new one.
  3. Ln2OC
    6 Dec 2004
    I'll do that.
    Cheers
  4. webbyman
    webbyman Hax.
    7 Oct 2004
    i also have 2 scsi drives... *which i found* ones a 36gb and other 9.1Gb i would like to see if ther work but i don't have a scsi card to test them with :waah:
  5. r00t69
    r00t69 What's a Dremel?
    2 Apr 2005
    Hi Ln2OC, I note you're in Dublin also. I don't know if this is the right forum but I have an Adaptec 39160 - dual channel ultra 160 PCI-X Card for sale if you need it.
    I've sent you a PM in case you miss this post.
  6. Cruelinios
    Cruelinios EvE Addict
    21 Jan 2002
    Im running a mixture of U320 SCSI HDD's on my rig, im using an Adaptec 29160N that I bought off fleabay for about 25 quid. Its a PCI card (not PCI-X so doesnt require a 64bit PCI slot) and works really well, you can run up to 15 drives off of one channel with no worries of performance loss as SCSI has NCQ (native command queuing - the technology that most SATA drives now have).
    So search ebay for 29160N, there are plenty out there ...
  7. Cruelinios
    21 Jan 2002
  8. r00t69
    2 Apr 2005
    PCI-X Cards will work in a standard PCI slot they will just run at PCI's native 32bit rather then PCI-X's 64bit.
    The total number of devices you can run off a single SCSI Channel is 15, so that would mean 14 HDD and one ID for the Controller itself unless you start messing with Luns!
  9. Mister_Tad
    27 Dec 2002
    actually, there are 16 IDs - up to 15 and inclusive of 0
    meaning you can have 15 drives per channel and one ID for the controller
    in a 32/33 pci slot i woudnt recommend running much more than a few drives, as while scsi can quite happily handle it, youre still piping it through a bus with a maxumum theoretical bandwidth of 133MB/sec
