Scythe 120mm Fans with 38mm thickness and Higher Static Pressure
Discussion in 'Industry News' started by Guest-16, 15 Oct 2007.
  1. Guest-16
    Guest-16 Guest
    Scythe Co., Ltd (Tokyo, Japan) announces three new 120mm fans. These new fans provide a better performance by integrating the higher "Static Pressure" feature. Unlike the common fans with 25mm thickness, the new "Ultra Kaze 120" comes with 38mm thickness. The slowest model (DFS123812L-1000) is specified with 1000RPM, 19,81dBA and 44,44CFM. Furthermore, it is designed for silent operation in a PC system. Other models of "Ultra Kaze 120" (DFS123812L-2000 and DFS123812L-3000) aim for enthusiasts who are seeking high performance and high airflow for their PCs. These fans are ideal and can maximize the performance Heatsinks that have a higher number of fins and a smaller distance between the fins. The following graphs show a comparison between the new "Ultra Kaze 120" fans, Scythe standard fans (supplied with Scythe 120mm CPU Coolers), and Scythe S-FLEX Version D (800RPM).
    Model Name: Ultra Kaze 120mm Case Fan (1000rpm/2000rpm/3000rpm)
    Model #: DFS123812L-1000 (1000rpm version)
    DFS123812L-2000 (2000rpm version)
    DFS123812H-3000 (3000rpm version)
    Manufacturer: Scythe Co., Ltd. Japan
    Dimensions: 120 x 120 x 38mm
    Specifications: 19.81dBA / 44.44CFM / DC12V / 0.25A (1000rpm version)
    32.91dBA / 87.63CFM / DC12V / 0.25A (2000rpm version)
    45.90dBA / 133.60CFM / DC12V / 0.60A (3000rpm version)
    Weight: 225g
    Connector: 3-pin (3-pin to 4pin adaptor included)
    Cable Length: 30cm
    Bearing Type: Sleeve Bearing
    MTBF: 30,000 hours
    MSRP: 8.90 (USD)
    7.56 (EURO) excl. VAT
    Product Page
    (Ed - FYI: Kaze pronounced "Ka" (like the Ford model) "Ze" (like you're saying the first two leds of Zed) translated into English means "wind", which seems appropriate for a 45dB, 133CFM monster! 30cm cables but only sleeve bearings though?)
  2. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Finally. I was hoping they'd do this!
  3. keir
    keir S p i t F i r e
    5 Oct 2003
    sounds like exactly what I need!
