Scythe Anniversary All Copper Ninja CPU Cooler
Discussion in 'Industry News' started by Guest-16, 16 Jan 2008.
  1. Guest-16
    Guest-16 Guest
    Scythe Co., Ltd (Tokyo, Japan) announces its 5th anniversary edition of Ninja CPU Cooler in all copper material! Year 2008 is the 5th year for Scythe brand since its establishment and this model is being announced as the 5th anniversary of Scythe. This copper version comes with luxurious all copper heatsink fins as well as a slower speed fan to fully benefit from the higher performance and heat transfer ratio of the copper to make this cooler even more silent and powerful.
    Quantity is limited for this version due to the nature of the material. This model is featuring the LGA775 back-plate mounting mechanism to increase the contact pressure and secure the mounting to compensate the weight of the all copper design. If you are looking for a luxurious all copper CPU cooler, this might be the good choice for you! For further details and specifications of this item, please refer to the below.
    Model Name: Ninja Cu CPU Cooler
    Model Number: SCNJ-CU1000
    Manufacturer: Scythe Co., Ltd. Japan
    Compatibility: Intel® Sockel 478/T (LGA775)
    AMD Sockel 754/939/940/AM2
    Heatsink Dimensions: 110 x 110 x 150mm
    Fan Dimensions: 120 x 120 x 25mm
    Fan Noise Level: 10,70dBA
    Air Flow: 40,17CFM
    Fan Speed: 800rpm (±10%)
    Weight: 1015g (+115g Fan)
    MSRP: 70.00 (USD)
    59.90 (EURO) excl. VAT
    For further information & images regarding this product,
    please visit our website at: http://www.scythe-eu.com/en/products/cpu-cooler/ninja-cu.html
    Ninja CU CPU Cooler Product Page (German)
    Ninja CU CPU Cooler High Resolution Images (FTP): ftp://scythe-eu.com/High Resolution Images/Products/CPU Cooler/Ninja Cu (SCNJ-CU1000)
  2. Guest-16
    Guest-16 Guest
    I saw this at Computex last year and Scythe were concerned about a reliable source of copper and the weight, so I'm kind of surprised to see it released as it's 1kg! but it does say limited quantities. QuietPC stock them in the UK - we're trying to get one in for review.
  3. Guest-23315
    Guest-23315 Guest
    Should be a good cooler indeed.
    But, why no copper base?
  4. Jipa
    5 Feb 2004
    Seems to be such a waste of copper. It weights a ton and I'm pretty sceptical about the difference in cooling power. Also I'd make a guess that the base is copper, but only nickel-plated to prevent oxidising and add some bling.
    EDIT: Just to add, Cooler Master did something similar already closer to four years ago. All copper and close to one kilogram: http://metku.net/index.html?path=reviews/hyper6/index_eng It was just too much back then and it still is today. Imo.
  5. Amon
    Amon inch-perfect
    1 Jun 2007
    Needs a complementary ninja decal to complete the orange ninja motif:
