Scythe Black & Copper Brother Joins! Original Designed RAM Cooler "Kama Wing"
Discussion in 'Industry News' started by Guest-16, 25 Sep 2007.
  1. Guest-16
    Guest-16 Guest
    Scythe Co., Ltd (Tokyo, Japan) announces the "black-coated" and "copper" versions of its "original" designed Memory Cooler, Kama Wing. The design is originally made by the Scythe engineer to increase the heat spreading area as well as an "angled" design to minimize the interference with components installed on the motherboard. 2 thermal sheets are included to increase the cooling performance. Black version is all aluminum made with electroplated in black color & copper version consists of 100% genuine copper, and includes 2pcs (1 set) as a value for money package!
    Model Name: Kama Wing (Black), Kama Wing (Copper)
    Model #: SCKW-1000BK (Black), SCKW-1000CU (Copper)
    Manufacturer: Scythe Co., Ltd. Japan
    Dimensions: 125 x 39 x 10 mm (W x D x Thickness) *Same for both models, *Thickness with extended fin portion is measured as 31mm
    Compatibility: SDRAM/DDR/DDR2/DDR3, Ready for Single/Double Sided Memory
    Weight: 25g (Black) – 1pc weight, 105g (Copper) – 1pc weight
    Accessory: Thermal Sheets
    Material: Aluminum (Black), Copper (Copper)
    MSRP: 9,80 (USD) – (Black), 8,40 (EURO) excl. VAT – (Black), 19,80 (USD) – (Copper), 14,25 (EURO) excl. VAT – (Copper)
    http://www.scythe-eu.com/en/products/ram-kuehhler/kama-wing-cu.html
    http://www.scythe-eu.com/en/products/ram-kuehhler/kama-wing-bk.html
  2. Guest-23315
    Guest-23315 Guest
    Looks like another lame way to spend money on something that isn't needed.
  3. specofdust
    specofdust Banned
    26 Feb 2005
    As much as it annoys me to say this, I agree.
  4. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    If you like hot running, uncooled ram, sure.
  5. Guest-23315
    Guest-23315 Guest
    Its really not going to do that much, seeing as most performance RAM comes with heat-spreaders anyway, and RAM without heatspreaders (BH-5 and stuff aside) isn't usually OC'ed to the point where its going to need extra cooling above the case's airflow.
  6. Tulatin
    16 Oct 2003
    There's a fair deal of micron DDR2 that wasn't sold as "performance", but when you can pay PC4200 prices for D9GKX? Hello.
    Besides, this puts a heat dissipating wing in the way of airflow to your performance heatsink, thus helping cool the ram
  7. Guest-23315
    Guest-23315 Guest
    Would you pay for it?
  8. Tulatin
    16 Oct 2003
    If i found 4x1GB Sticks of well clocking "value" ram which was bare, and these sinks prove to offer some form of cooling performance, then yeah. wedging fans is a PITFA
  9. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Certainly not for what they're going for, no.
  10. Guest-23315
    Guest-23315 Guest
    You'd be looking at over £25 for four of these and when you can get something that not only works, but looks fricking cool like the OCZ RAM Cooler for under £15...
