News Scythe makes even bigger coolers
Discussion in 'Article Discussion' started by CardJoe, 6 Mar 2008.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. Kierax
    Kierax What's a Dremel?
    5 Mar 2008
    My god...a silly side of me just wants that...badly...seriously..:D it looks awesome :D but I have to think even with a rear mounting plate it has to stress the motherboard?
  3. kenco_uk
    28 Nov 2003
    lol :lol:
    Crazy.
  4. specofdust
    specofdust Banned
    26 Feb 2005
    I thought we weren't allowed porn on bit-tech? :D
  5. naokaji
    naokaji whatever
    8 Dec 2006
    person a: bloody hell, I've just caried my 30 KG Computer upstairs...
    person b: I told you, you should have bought an Aluminium Case.
    person a: I did, but then I saw that new Scythe Cooler and coudn't resist.
    Seriously though, those coolers might be good as a epeen expander, but if they will actually fit in a case is very questionable and with Certain coolers *cough* Thermalright *cough* getting pretty close to Watercooling it's questionable if there will be much of an improvement any more in Aircooling or if we are simply getting to a point where water is necessary to get a improvement.
  6. Kierax
    5 Mar 2008
    Good point well made, I think Air Cooling also is sadly coming to an end in terms of the enthusiast area at least, home users will be happy with Air Cooled for ages to come yet.
  7. Veles
    Veles DUR HUR
    18 Nov 2005
    I don't think there's any reason for the average joe PC to be watercooled. Even some enthusiast PCs I struggle to believe really need watercooling sometimes.
  8. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    yup, water is a very nice e-peen tool, but with this aircooler even that last reason to go water falls away. Now the only real reason to watercool is that is just looks a whole lot better.
    Kudos for this post, made me lol
  9. Guest-23315
    Guest-23315 Guest
    That case looks quite nice
  10. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    I don't like the look of the thing at the top behind the door - it looks like a row of 40mm fans :eeek:
    Did they say when the cooler might be released?
    Edit: It looks like it will need a pole to hold it up!
  11. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    screw the cooler (my TR 120e works perfectly fine, and if i need better ill go water than putting that monster and snap my mobo), but the case looks pretty darn fine!
  12. naokaji
    naokaji whatever
    8 Dec 2006
    I wasnt really saying you have to watercool, but referring to the dimnishing returns that kick in at a certain point in aircooling which make aircooling not the best option after a certain point, yes, it could mean watercooling, but it could also mean that hw manufacturers should find a way to reduce the heat output of components.
  13. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    Its actualy the way around. If I have the choice between this and a watercooler. Then Ii would absolutly go watercooled. This 'thing' will probably rip the socket right from the motherboard including a part of the motherboars itself. It then will fall onto your 'very expensive' videocard, and rip this right off by the part that sits into the pci-e socket. Or worse, make some nice sparks flying around in your case. And what about a simple change of memory? You cant get to it because this 'thing' is blocking the whole top part of the motherboard.
    This 'thing' is so useless its not even funy...
  14. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    Ultimate HTPC cooler as far as i can see.. nothing less...
  15. Xtrafresh
    27 Dec 2007
    I agree to almost all your statements, apart from the fact that this thing is not funny! I think this idiotic contraption is hilarious.
    And umm may i remind you that anyone with enough of a brain to open the box and install will also have the sense to build something in the way of support. It's a cooler, not the stampede from Jumanji :nono:
    That's one thing i do miss in this cooler: some sort of a bracket at the far end, so we have a point where we can support the weight other then the mobo.
  16. Guest-16
    Guest-16 Guest
    You want porn? There was a topless woman advertising Be Quiet on the front of their stand - he upper body was painted with their logo.
    Bit tacky, and she wasn't too hot, but still, fun to see :D
    I dont know when the Orochi will be released, Scythe didn't say - more of "when it's ready".
  17. Amon
    Amon inch-perfect
    1 Jun 2007
    I was talking about this with some friends and we all agreed that a brace kit needs to be included to attach the cooler to the chassis. We also agreed that it needs more fin surface area to justify its sheer volume.
  18. mrb_no1
    mrb_no1 Pie Eater
    15 Sep 2007
    people talk of these things being heavy, look at them, copper piping with extremely thin al sheeting to help disopate the heat. For that to be heavy you'd have to have trouble lifting your own mouse and i mean, how much of a stereotypical geek are you? if that is the case, get out side and do some exercise or some/a pressup in your room ffs.
    My thoughts arent just plucked out of the air on this one, i own a scythe infinity, currently their biggest in the range and if that managed to break my mobo, i wouldnt be calling scythe, i'd be onto asus for selling me some piece 'o' crap mobo with no structural strength to be heard of.
    I like the idea of the new heatsink, although it will only serve to create a better mean temp imo, as someone mentioned, current air heatsinks are that good. It would be like having 50 rads in a watercooling loop rather than 3 with fans, the idle wont stand to change much, but the load temps will probably only change by a degree. Furthering that line of thinking, with the green theme everywhere and processors becoming more efficient and less power hungry, even oc'ed cores, the need for such a massive sink is becoming less improtant.
    peaec
    fatman
  19. Veles
    Veles DUR HUR
    18 Nov 2005
    No, the fault is squarely on yourself, you overloaded your motherboard. A mobo is only a thin piece of plastic, you can't expect to put anything too heavy on this (and weighing in at 1kg this is incredibly heavy for a regular CPU heatsink). That's why things like the zalman superflower coolers said that to transport the case you had to remove the cooler otherwise you risk damaging the mobo. The main problem with this is diminishing returns, you can get plenty of other coolers that weigh a fraction of the scythe and are much smaller but the cooling won't be much worse.
  20. Primoz
    Primoz What's a Dremel?
    22 Dec 2007
    Love the case, LOVE it.
Tags: Add Tags
