News Scythe makes even bigger coolers
Discussion in 'Article Discussion' started by CardJoe, 6 Mar 2008.
  1. supermonkey
    supermonkey Deal with it
    14 Apr 2004
    Don't forget that the cooler's weight won't be as simple as X grams pulling straight down. As the heatsink gets bigger, the weight is placed farther and farther from the attachment point. Think of the heatsink as a lever, and the bracket as the fulcrum. The farther the weight moves out, the more it will pull on the bracket. Add in the additional forces incurred when moving a computer and you have the potential for a giant heatsink to damage the motherboard. I don't think it's entirely unfounded.
    -monkey
  2. johnnyboy700
    johnnyboy700 Minimodder
    27 May 2007
    Sheesh, if they make this thing any bigger you could use it as a toast rack.
  3. mrb_no1
    mrb_no1 Pie Eater
    15 Sep 2007
    @supermonkey: i had forgotten my a level physics there, essentially a moment about a point, i see your point and agree with it totally. I still think the bracket on a high end mobo where this heatsink would probably end up should have a stronger bracket and plating where the heatsink would sit and surrounding parts to allow for it.
    peace
  4. LordPyrinc
    LordPyrinc Legomaniac
    7 Mar 2008
    And how much performance increase does this massive porcupine of a heatsink actually give you? In six months or less, a faster performing processor will smoke your heavily quilled processor. What indeed is the point?
  5. Xir
    Xir Modder
    26 Apr 2006
    ...Still, good to see an option for those who want to go fanless (and Pumless) ;-)
    As long as you don't carry it around.
    I wonder why not to use the entire casedoor as a heatsink directly to the outside...just connected by (made movable) Heatpipes, so taking load off the Mobo and the need for caseventilation.
    ...actually that would be quite easy for a watercooled setup...maybe I shoud try and patent it :-D
Tags: Add Tags
