Scythe Orochi Ultimate Fanless CPU Cooler
Discussion in 'Industry News' started by Guest-16, 26 Mar 2008.
  1. Guest-16
    Guest-16 Guest
    Scythe Co., Ltd (Tokyo, Japan) announces the group's top fanless ultimate CPU Cooler, 'Orochi'. The product name comes from the old time Japanese snake monster with 8 heads. Tuned to maximize the performance at the fanless or super low fan speed operation to make your system as silent as possible. Total 10 heatpipes and large heatsink surface enables this CPU cooler to enable the ultimate fanless operation for today's PC system. Thanks for the large cooling fin surface which makes both top-flow or side-flow cooling to be possible. Scythe original designed 140mm fan / 25mm thickness round-shaped fan is equipped for this CPU cooler as the most optimized cooling solution. For further details and specifications of this item, please refer to the below.
    Model Name:
    Orochi CPU Cooler
    Model Number:
    SCORC-1000
    Compatibility:
    Intel:
    Socket 478 All Speeds
    Socket T/(LGA)775 All Speeds
    AMD:
    Socket 754 All Speeds
    Socket 939 All Speeds
    Socket AM2 All Speeds
    Socket 940 All Speeds
    Dimension:
    120 x 194 x 155Mm / 47.24 x 76.38 x 61.02inch (Overall
    Dimension)
    140 x 140 x 25mm / 55.12 x 55.12 x 9.84inch (Fan Dimension)
    Fan Speed:
    500rpm (±10%)
    Fan Noise:
    10.8dBA
    Air Flow:
    29.39CFM
    Weight:
    1155g (Unit) + 130g (Fan)
    2.55lb (Unit) + 0.29lb (Fan)
    http://www.scythe-eu.com/en/products/cpu-cooler/orochi.html
  2. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Good god, the weight! I'd hate to drop that thing on my foot. :lol:
  3. Rege
    Rege New Member
    24 Mar 2008
    The weight is horrible. I wonder what mounting system is going to be neccessary. Perhaps it'l have to be mounted the one of the side panels apart from the usual straps ;)
  4. E.E.L. Ambiense
    26 Jul 2007
    I'm actually picturing a weight and pulley system....
  5. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    1155g?!?!?!?!?! That is ridiculous, there is no way in hell im putting that in a PC unless it is sitting flat with foam supports behind the motherboard.
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    The copper Ninja is only 1,015g...
    Or a hydrogen balloon...
  7. naokaji
    naokaji whatever
    8 Dec 2006
    frostytech.com has a review up, looks like that cooler would be what silent freaks want, can't hear it and still performs well.
