News SDHC to be replaced by SDXC
Discussion in 'Article Discussion' started by CardJoe, 6 Mar 2009.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. phuzz
    phuzz This is a title
    28 May 2004
    Perhaps, given what M$ are doing to TomTom at the moment, a storage scheme based on an actually free file system would be better?
  3. UncertainGod
    UncertainGod Minimodder
    18 Oct 2007
    Why did they choose to go with exFAT for the file system?
  4. Flexible_Lorry
    Flexible_Lorry What's a Dremel?
    6 Dec 2008
    I will take 2TB of pictures and force my family to live through every single one
  5. TomH
    TomH BELTALOWDA!
    28 Nov 2002
    More than likely due to the extremely small over-heads it carries. And that's before you get to the similarities between FAT32 and FAT64, making it a simpler 'port' for your firmwares.
    I digress, a free file system would be preferable.
    I somehow don't think TomTom will be using >32GiB of space any time soon, however.
  6. scarrmrcc
    scarrmrcc What's a Dremel?
    12 Nov 2007
    "While the form factor is the same as the SDHC – and SD – cards before it, the good news stops there: SDXC is completely incompatible with both SD and SDHC-based systems, and will require specially designed hardware to take advantage of the increased speed and capacity it offers"
    so then why use the same form factor? is it to fool idiots into buying it, thinking it will work in their stuff, when it wont?
  7. Gareth Halfacree
    4 Dec 2007
    Same reason SDHC uses the SD form factor despite being incompatible - SD cards will work fine in SDHC devices, just not the other way around. Likewise, SD/SDHC cards should work fine in SDXC devices, just not the other way around.
    If you buy a new camera, imagine how ticked off you'd be if you couldn't use any of your old memory cards.
  8. B3CK
    B3CK Minimodder
    14 Jun 2004
    I spoke at length with every Scandisc employee, even their tech's at CES about this new xd card they are putting out. They have absolutely no plans to implement read/write speeds to pc at a data rate that compares to the camera/device ability to write/read to the card installed.
    Examples were camera writing to it near future can write at 300mbs but that when the camera or even card reader in the pc would still transfer at standard usb speeds.
    When I asked all their sales reps, they sent me to the tech's and engineer on hand, who had no answer. Their only answer was they were really marketing at the new HD cameras that take crazy sized hd video; and the new 3d cameras that use more than one capture feed. While enabling the cameras to save enough data fast enough, and have enough room, they were not so forward thinking on how to get that data from the camera to the pc. While the cameras capable of doing said things are corporation level expensive, they will leave the camera transfering tech to the camera people.
    NOW ON THE OTHER HAND;
    I seem to remember a small drive the size of a notebook hard drive that had 4 slots for sd cards. imagine using 4 of these new xd cards, on one side, and as the current nice feature use a second controller to provide effective raid to 4 more cards on the reverse side, 16Tb flash drive Cheesecake!
  9. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    wow 2tb on an SD card, thats just nuts, I hope this applies to the SDD market ^__^
  10. TomH
    TomH BELTALOWDA!
    28 Nov 2002
    Happened before, it'll happen again: you'd be shocked at how many people I had to tell, between 2006 and 2008, that their SmartMedia cards and (original) Memory Sticks weren't going to fit any new cameras.
  11. Cobalt
    Cobalt What's a Dremel?
    24 Feb 2006
    Its not like we'll be getting them in 2TB capacities any time soon, its just the format that supports that as a max capacity.
  12. ZERO <ibis>
    ZERO <ibis> Minimodder
    22 Feb 2005
    OMG even 100mbs would be nice especially on upcoming phone devices that can play 720p!
  13. Neji
    Neji Minimodder
    3 Jan 2006
    Can Windows even read any other file system than FATxx?
  14. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    No, of course not. That's why NTFS doesn't work with any Windows OS. :eyebrow:
    Proprietary? Why, oh why?
  15. ParaHelix.org
    ParaHelix.org What's a Dremel?
    19 Jun 2008
    Did I miss somthing?
  16. TomH
    TomH BELTALOWDA!
    28 Nov 2002
    Only the blatant sarcasm.
    NTFS/FAT32/FAT have been supported for some time. FAT64 (exFAT) is new.
    Then you can have Installable File Systems (IFS) that range from ext2 to HFS+, etc.
    And they were meant to be on WinFS by Vista, but that never happened. :hehe:
  17. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    uh, no ****? thats a limitation of USB2, hardly their fault
    you'd need an eSATA card reader or some other interface
  18. outlawaol
    outlawaol Geeked since 1982
    18 Jul 2007
    2Tb on a SD card is ridiculous. Using an array of smaller cards has it advantages, like if one card goes bad your others are fine.
    If anything the new standard on cameras is that every brand/model/type has two slots. I would love to have a redundant backup on camera (I know some pro cameras have this, but who wants to spend $6k on a camera, other then Vers ;) )
    Long live CF! :D
  19. Kidzoom
    Kidzoom What's a Dremel?
    22 May 2010
    How about utilized as a 1-2 TB really compact device to back up my hard drive?
    Could easily back up system to multiple cards and throw it in a fire proof safe or carry off site.
    Even better as an array to back up the entire system. Just a fear factor of "misplacing" a $600+ card with all your data. Must Encrypt!
  20. DBNemesis
    DBNemesis What's a Dremel?
    30 May 2010
    I've been using a couple of 32GB cards with my SLR and even for large cameras, it seems more useful to have multiple cards at that size, as you stand to lose a ton of valuable photos already. that said, HD videos or 3D would be great to have the size. I'll be happy with 32GB for a while yet though.
Tags: Add Tags
