News Seagate confirms 3TB drives
Discussion in 'Article Discussion' started by CardJoe, 19 May 2010.
  1. ModMonkey
    ModMonkey Size 11 Carbon footprint
    22 Sep 2003
    Wouldn't touch seagate again, but hope my Drobo FS will accept a Samsung\WD version of these drives.
  2. Unknownsock
    Unknownsock New Member
    13 Jul 2009
    Never heard of segate drives :eek:
  3. Bayaz
    Bayaz New Member
    4 May 2010
    Why not just buy 2 * 2GB drives instead. Probably work out cheaper and less troublesome until hardware/software catches up
  4. NeoThermic
    NeoThermic New Member
    16 May 2009
    Not sure I agree with this post. 48-bit LBA, part of the ATA-6 spec released in 2002 gives support for 128 PiB worth of disk addressing. Quite why you'd need a BIOS, SATA, RAID or mobo is beyond me. Craig, Gareth, can you enlighten us as to why 48-bit LBA isn't enough for 3TB drives?
  5. Anfield
    Anfield Well-Known Member
    15 Jan 2010
    So according to the Thinq article linked you would require a mainboard with UEFI instead of Bios... problem is that the only manufacturer to offer it at some point in consumer mainboards (msi) seems to have abandoned it already again with not a single s1366 / s1566 / am3 board having it according to their own website.
    http://www.msi.com/html/popup/MB/uefi/applied_model.html
    And server mainboards are even worse than consumer products if it comes to being hooked on ancient connectors and standards...
    So that supposed UEFI requirement better be wrong.
Tags: Add Tags
