Windows searching for a burning program for avi to dvd
Discussion in 'Software' started by tigra, 4 Dec 2004.
  1. tigra
    tigra What's a Dremel?
    23 Oct 2004
    i need to find a dvd burning program,
    1 that can burn .avi files on a way that i can watch them on my dvd (tv) player
    any idea's
  2. Guest-16
    Guest-16 Guest
    Nero - with SVCD plugin.
    Or, use an AVI to MPEG converter from doom9.net/org and convert the file, then burn it as SVCD in nero.
    Basically DVD drives will read anything mpeg.
    SVCD is mpeg2, VCD is mpeg1.
  3. tk421
    tk421 Idiot.
    15 Jan 2002
    i had a problem transcoding like that - guy my neighbor works with had 4 misnamed files
    (labelled .mpg, when they were actually mpeg-4 .avi's) that he wanted on dvd.
    i ended up using nero to burn svcd - worked fine, played in everything i threw em at.
  4. tigra
    23 Oct 2004
    now i need a media player with a div3 decoder
    any ideas
  5. tigra
    23 Oct 2004
    so if i burn a mpeg file with nero on a dvd and put it in my dvd player
    i should be able to watch it?
  6. Guest-16
    Guest-16 Guest
    depends on your DVD player. If its fairly recent (last year or two) then there should be no problem. If you burn it specifically as SVCD to a CD (providing itll fit) then its more likely to (a little more).
  7. tigra
    23 Oct 2004
    i have madmax1.avi madmax2.avi madmax3.avi
    so if i convert them into mpeg
    and then burn them on a data disc with nero
    then it should work
    (yes i have a verry recent dvd player)
  8. Guest-16
    Guest-16 Guest
    yea, should work.
    If they are continuations of each other you can combine them whilst in avi using virtuadub.
  9. theflinger
    theflinger What's a Dremel?
    21 Mar 2004
    http://www.videohelp.com/dvdplayers has a sweet database of DVD players. What you need is your player model number, plug it in, make sure it can read VCD. If you want SVCD (probably), make sure it says SVCD or VCD header trick. They might have a link about the header trick, if not, I'll help you out with that. Google it if you feel unlazy ;)
  10. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    no you dont burn them as data. You toss them into the Video_TS folder and nero should cut them up properly.
