Cases Searching for a PC case...
Discussion in 'Hardware' started by Arthur, 13 Mar 2010.
  1. Arthur
    Arthur Comment is over there ----->
    24 Nov 2009
    Hi folks :)
    I am looking to purchase a chassis that can accomodate 2 x 360mm radiators and also 1 x 120mm radiator.
    There will be 3 watercooling loops going inside this case.
    I currently have a coolermaster cosmos s
    Been googling for a couple of hours but not found anything with these requirements so far.
    Any suggestions on manufacturers / models very welcome.
    Cheers :thumb:
  2. Krikkit
    21 Jan 2003
    Plenty of cases out there you can cram this lot into. My Chieftec big tower for one.
    One 360 in the floor, t'other in the roof and a 120 at the rear somewhere.
    Why 3 loops though?
  3. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
  4. Arthur
    24 Nov 2009
    I want to make use of the 3 pumps and reservoirs i have lying around but the main reason is because it is do'able :)
    What model number is your case Krikkit ?
    Thanks for the pointers guys :clap:
  5. Krikkit
    21 Jan 2003
    This is my case, only instead of feet I have casters. Absolutely enormous, yet still looks reasonably low-key. :)
    Pic of the inside:
  6. Arthur
    24 Nov 2009
    Hmm.....thanks :)
    what i really am after is a chassis that already has housing / holes already drilled for the rads etc.Do these cases exist or will it be a mod requirement ?
    Thanks again.
  7. Burnout21
    9 Sep 2005
    The only cases available like that are mountain mods cases, no other case manufacturers design there case for your requirements.
    The corsair 800D i believe has room for a 120.2 rad in the roof, but mostly we have to mod. Rather than making cases for watercooling, they are designing for larger fans such as 140mm and 200mm fans.
  8. Arthur
    24 Nov 2009
    Cheers for this info.....helps a lot :thumb:
