News Seasonic launches new Prime Fanless PSUs
Discussion in 'Article Discussion' started by bit-tech, 3 Mar 2020.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. adidan
    25 Mar 2009
    Be good if you can get your hands on one and give it a review.
  3. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Does your case have a PSU mount where the space-where-the-fan-would-go can face up and out of the case? If so, you can put in a fanless PSU no problem. If the fan-hole can only face down, then a fanless PSU is not a good choice.
  4. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    I had one of their previous fanless PSU. Love it, but I think their hybdrid design is the better options. I have read, but not confirmed, that Seasonic under rated the fansless PSUn order to ensure their reliability under full load, i.e. a supply rated to 400W fanless could push more power with active cooling (I don't recall how much more). The issue is that most computer use cases don't draw max power for extended periods of time, thus the hybrid design allows for hardware that is not oversized (cheaper) and will actively cool only when required.
  5. Dr. Coin
    13 Sep 2013
    I'd look at Seasonic's Focus Plus series, offers the hybrid fan control, including full off. As for cables I don't know about custom jobs but Seasonic sells extras and replacements through a partner site: https://www.btosinte.com/Cables-for-PS2-power-supply_c7.htm
    Edit:
    While double checking the URL worked, I noticed that BTOS Integration does do custom lengths and connector counts.
  6. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    ^^This^^ Unless you're going for a fully passive under load system the hybrids are a better option.
  7. Anfield
    Anfield Multimodder
    15 Jan 2010
    Custom PSU cables are very much a niche product, no point offering them for anything but the most popular PSUs.
    Guest-44638 likes this.
  8. GeorgeStorm
    16 Dec 2008
    There are people who will do custom cables for PSUs.
    Pexon pcs should be able to do whatever you'd like I believe.
    cobalt6700 likes this.
  9. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    What he said. My NH-D15 will always spin a little, so will the fans on my graphics card. Even though I can get my system to be almost silent, the power draw is just to high to go passive. I think that's true for most halfway gaming-focussed builds.
  10. Anfield
    Anfield Multimodder
    15 Jan 2010
    If you use high quality fans and run them at low rpm you can easily sleep right next to them anyway.
  11. frack
    frack What's a Dremel?
    28 Feb 2020
    fanless is nice, but will it be worth it to use in a gaming pc?
    Diletta Graziosi likes this.
  12. Diletta Graziosi
    Diletta Graziosi What's a Dremel?
    27 Feb 2020
    most of the time with my Prime titanium the fan are not moving att all, so it could be a nice idea, seasonic knows hot to do good psu, my question is, is it Worth it? i mean the fan is really quiet, so i can trade a little bit of noise for more longevity all day
    you got the point
  13. Hardware_Numb3rs
    Hardware_Numb3rs What's a Dremel?
    21 Apr 2019
    With the right components yes, I have a Seasonic 520W fanless and paired with a low noise GPU like the 5600XT or the 1660s youcan build. a pretty nice living room gaming machine, also as a home theater
  14. Dr. Coin
    13 Sep 2013
    High end gaming machine probably no, but there are people and companies attempting to build passively cooled high end systems who'd like a fanless PSU. Other applications such and a office, HTPC, etc are better suited for fanless PSUs and it will make a difference. I acknowledge that for office and HTPC one is unlikely to be using a high end 700W Seasonic PSU.
    A high quality fan is low noise indeed but it is not 100% silent. Having built a computer with no moving parts, there is a noticeable deference between very silent and zero noise. Interestingly I did not put my 400W fanless PSU in to my HTPC, but my main rig.
  15. frack
    28 Feb 2020
    it is probably a little more "niche" market for particular applications, you are right :)
    yes but considering power efficency... the power supply dissipates at least 50-60 watts... it's not a proper joke to do this...
    Seriously?? :O
  16. Diletta Graziosi
    27 Feb 2020
    absolutely, the seasonic Platform is very efficient, and the heat produced is well dissipated by the internal heatsinks
  17. frack
    28 Feb 2020
    how is it healthy for a supply power to work at higher temperatures... well this is a different story
  18. Diletta Graziosi
    27 Feb 2020
    in fact is not, that's why i Always prefer to have the fans, now it's winter, but during intense workload in summer it will for sure come handy.
  19. frack
    28 Feb 2020
    it's a good reason to go to beach during the summer :p
  20. ooey
    ooey What's a Dremel?
    21 Oct 2010
    PSUs should ALWAYS have a fan.
Tags: Add Tags
