Hardware Seasonic M12D SS-850W PSU
Discussion in 'Article Discussion' started by Tim S, 19 Mar 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. g3n3tiX
    g3n3tiX Minimodder
    3 Jun 2006
    Nice one.
    I'm still happy with my dark power pro 750 I bought a month ago. Their service is incredibly good (free number, rep is in my country, very friendly and knowledgeable) and the noise is inexistent.
  3. Htr-Labs
    Htr-Labs What's a Dremel?
    16 Jun 2008
  4. Guest-16
    Guest-16 Guest
    The M12D specifically is only available in 750W and 850W versions. There are similar models now with those modular connectors but the efficiency won't be so high and they will use ADDA fans not SD. :)
  5. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I was looking at the M12-2 430W a while back, seemed better bang/buck than the 450W modular Corsair, but it seems to have gone unobtainium. :waah:
    But they're pretty efficient,
    I bet a whole packet of cookies an OTT PSU wastes more heat than one sensibly sized. :geek:
  6. Guest-16
    Guest-16 Guest
    I'll take that bag of cookies then, because at 20% load (170W) the M12D 850W is 86+% efficient.
  7. cpemma
    cpemma Ecky thump
    27 Nov 2001
    And your article (or rather the chart on p5) shows smaller supplies, say half the size at double the load, would have higher efficiencies. Go to the OTT 1000W PSU and the effect is even more marked.
Tags: Add Tags
