Modding Second Headphone Socket
Discussion in 'Modding' started by MeRviN, 23 Jul 2005.
  1. MeRviN
    MeRviN What's a Dremel?
    19 Mar 2003
    I am getting a new case soon and it has a headphone socket (mic, usb) on the front of the case is there any way of setting them up so i dont have to keep swapping wires over?
  2. mobius9
    mobius9 Minimodder
    4 May 2004
    Alot of motherboards have pin connectors for front audio, much like the front usb, etc. I'm sure your AV8 has those, look in the manual for front audio.
  3. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    Just be careful if you care about audio quality alot (and I mean alot). When I hooked up the front panel audio on a A7N8X-D there was a very slight buzzing sound that drove me crazy. The buzzing came from the speakers reguardless if I pluged them in to the sockets on the back or to the extended ones on the front. Just a word of warning.
  4. scifi3018
    scifi3018 Minimodder
    6 Feb 2005
    if your MB doesnt have pins, or the front panel has a 3.5mm jack, then you can buy a spliter from anywere, just make sure that each output has both chanels, instead of one being L and one R
  5. Kobalt
    Kobalt What's a Dremel?
    26 Aug 2003
    Agreed [​IMG]
  6. fishthecat
    fishthecat What's a Dremel?
    6 Mar 2002
