Graphics Secondary monitor which connection
Discussion in 'Hardware' started by Kronos, 31 May 2015.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    I have an OCUK GTX980 which has 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI and my primary monitor a Dell U2711is connected via DVI so which should I use for the secondary a Dell U2410?
  2. GeorgeK
    18 Sep 2010
    Doesn't matter in my experience - both HDMI and Displayport work with 1920x1200 screens.
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    That was quick. Cheers George. Need to drag out the cable box and see what I have.
  4. Kronos
    Kronos Multimodder
    6 Nov 2009
    OK on connecting the 24inch via HDMI on booting up my PC sees it as the primary monitor which I switched in the Screen Resolution but it is still numbered 1 and the 27inch is numbered 2 not a major issue but a niggle and I hate niggles.
    Can I number them correctly in some way?
  5. GeorgeK
    18 Sep 2010
    If you right-click on the desktop and select screen resolution I think you can swap them round in there :thumb:
  6. Kronos
    Kronos Multimodder
    6 Nov 2009
    They still retain the wrong numbers. My 27inch is listed as 2 and the 24 nch as 1.
  7. lava
    lava Minimodder
    18 Sep 2010
    As above, if you right click on the monitor that's set as 2 I'm pretty sure the option is "Make primary" and that'll swap them around
  8. Kronos
    Kronos Multimodder
    6 Nov 2009
    Nope it certainly makes the 27inch the primary but it is still listed as number 2. I am sure it is a GPU thing and which connection takes precedence. As I said it is a niggle nothing more.
  9. Pete J
    Pete J Employed scum
    28 Sep 2009
    Kronos, please would you do me a favour (it may also help you out with your niggle)? Please will you connect your Dell U2711 with the HDMI and see if you can still output at 2560x1440 resolution?
  10. Kronos
    Kronos Multimodder
    6 Nov 2009
    Simple one Pete. No. Screen Res is 1920 x 1080.
    Edit: Obviously with just the 27inch connected it is numbered 1, plug in the 24 inch and it becomes 1 and the 27inch 2.
  11. Newton Sporkfondle
    Newton Sporkfondle Spork, the all-purpose eating tool!
    30 Mar 2015
  12. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    It is, but it can't do that over HDMI.
    Glenn, I am in the same boat and I've just had to live with it. My rarely used TV on HDMI is number 1, my main 23" on DVI is 2 and my secondary monitor, also on DVI, is 3.
  13. Kronos
    Kronos Multimodder
    6 Nov 2009
  14. Parge
    16 Jul 2010
    Max res over that HDMI will be 1920*1080. For higher you need dual link DVI or display port.
  15. Kronos
    Kronos Multimodder
    6 Nov 2009
    As I said Chris just a niggle. I am sure I looked into this a while back but for the life of me cannot find the article. And it is all to do with the way the connections on the GPU are prioritised.
  16. Pete J
    28 Sep 2009
    That's a pity. HDMI 1.4, which I think your monitor should have (though internet searches say there's an internal 'limiter' in that particular monitor), is supposed to be able to support 4K @24FPS but I've not seen anyone actually get that.
    Thanks for checking!
