SketchUp Securing a tiny circuit board to a plastic cap?
Discussion in 'Modding' started by Weekly_Estimate, 16 Jul 2018.
  1. Weekly_Estimate
    Weekly_Estimate Random bird noises.
    1 Feb 2010
    Hello!
    Does anyone have any idea how i can mount this tiny circuit board onto a plastic cap in basically a T Shape?
    It’s going to have to be sturdy to because it does take a little bit of effort putting the cable in.
    The Charging port will be going straight though the cap so <---- that way
    all the room around the module chip is dead space so it can all be used for supports
    Idea
    Circuit Board
  2. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    If I understand your requirements then you could put some small bolts through the lead holes to bolt it to the cap. Then secure your leads between two nuts. Add some solder for a good contact.
  3. Weekly_Estimate
    1 Feb 2010
    Interesting, thanks for the suggestion i just realised the micro usb port only gives me about 2mm of travel so i’ll have to drill out plastic from the cap, make sure its snug, then i can secure using your technique by making two little holes which go from the roof to the bottom of the cap though the module board holes which is held in by little bolts or pins, damn this is close to watchmakers territory
  4. Brijac
    Brijac What's a Dremel?
    16 Feb 2018
    Dr. Coin suggestion witll be most durable. You can also try hot glue, if you dont want to drill holes..
  5. Weekly_Estimate
    1 Feb 2010
    Are you sure hot glue would hold? and just hot glue from a glue gun or a specific type?
    I remember watching a bigclive tear down video on youtube, and he toke something apart and on the circuit board it had this yellow strong gunky material not allowing him to inspect the board, i'm trying to find the video to find out what the heck it was anyone know?
  6. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    100% would hold. It's strong stuff. hot glue from a glue gun would work. I'd be more worried about not being able to get it off again.
  7. Weekly_Estimate
    1 Feb 2010
    Perfect, thank you both
  8. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    PC case stand off pins screwed into the cap and then screw the board on to the stand offs?
    Hot glue would work but as you mentioned it's whether you wanted to remove later, I use hot glue when I know I never want to remove something
  9. Weekly_Estimate
    1 Feb 2010
    I'm going to epoxy the cap in to avoid removal, thanks for the suggestion though
  10. Cheapskate
    13 May 2007
    @Evolutionsic - Sorry for being late to the party, but the yellow gunky stuff is contact cement. LOVE that stuff.
  11. Weekly_Estimate
    1 Feb 2010
    Thanks for clearing that up :), in the end i just printed extra plastic behind the board holding the module board in place, hindsight eh :)
