Seemingly Simple Hard Disk question
Discussion in 'Hardware' started by Anator, 15 Oct 2005.
  1. Anator
    Anator What's a Dremel?
    26 Feb 2004
    I cant believe im asking this, as it seems the most simple thing ever.
    What's the easiest way to completly clone a hard disk, from one to another?
    Just tried a select all and drag over with both of the drives in a pc(with hidden files visible), but its obviously missing some key OS files or something as it says no os detected when i try the new drive.
  2. atanum141
    22 Jul 2004
    Ghost it.....
    Norton Ghost or other "imaging"(sp?) softwares
  3. hitman012
    hitman012 Minimodder
    6 May 2005
    Quite a coincidence - I had to do this today. I used Acronis TrueImage's wizard to completely clone a 40GB disk across to a new 200GB one for a friend. It only took about half an hour and I'd highly recommend the software for its ease of use :)
  4. Hippo
    Hippo Pre-dates 5.25" Floppies
    7 Mar 2003
    I've had problems with Norton Ghost in the past where Acronis True Image has worked every time.
    Edit: Hitman beat me to it!
  5. Anator
    26 Feb 2004
    Just trying a program called R-Drive Image will let you know the results. I knew about imaging software but couldnt remember whether there was some way to do it from within windows xp, but evidentally there isn't.
  6. Anator
    26 Feb 2004
    Worked fine :) Only a 15 day trial on it though for those that want to try.
  7. Pookeyhead
    30 Jan 2004
    Norton Ghost Cheesecake :rock:
  8. dire_wolf
    dire_wolf Last Of The Dovakhiin
    24 Jul 2002
    I'd go with acronis tbh, it's probably the easiest, no-fuss program for the job and I've never had a hiccup from it once . . .
