Other Seems like no browser is safe
Discussion in 'Software' started by Dr. Strangelove, 23 Mar 2009.
  1. Dr. Strangelove
    Dr. Strangelove What's a Dremel?
    13 Mar 2005
  2. Turbotab
    Turbotab I don't touch type, I tard type
    4 Feb 2009
    I wonder whether the computers they used to hack the browsers were fully patched?
  3. Dr. Strangelove
    13 Mar 2005
  4. ch424
    ch424 Design Warrior
    26 May 2004
    I think that later in the competition (tomorrow?) they install java and flash, which should make chrome easier to hack...
  5. EnglishLion
    EnglishLion working for the good of mankind...
    2 May 2008
    All browsers are perfectly safe if you use them without an internet connection!
  6. azrael-
    azrael- I'm special...
    18 May 2008
    Give Lynx a go... :)
  7. Ryu_ookami
    Ryu_ookami I write therefore I suffer.
    11 Mar 2004
    How is an underarm deoderant going to help?
  8. azrael-
    18 May 2008
  9. Dr. Strangelove
    13 Mar 2005
  10. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    I'm pretty sure IE1 would be very safe to use. :) After all there's nothing to hack, really. It doesn't even know about cookies, only super basic HTML. I think even IE2 would be pretty safe, the first security hole was discovered in IE3.
  11. Dr. Strangelove
    13 Mar 2005
    I think it's more likely to be safe due to the fact that no one would ever expect you to use it, hence no one would bother writing an exploit for it ;)
  12. mm vr
    18 Nov 2007
    But you can't exploit anything in it.. I mean, there just are not functions that you could exploit!
    It's like trying to hack into a banana!
  13. Dr. Strangelove
    13 Mar 2005
    hehe true on the other hand they probably said that about several incarnations of IE/FF/ect ;)
    Hmm hacking a banana no fair now you made me hungry....
  14. wolfticket
    19 Apr 2008
    If it seems like no browser is safe, then that would be because no browser is safe.
    By its very nature, browser security will always lag behind exploits.
    How many and how serous depends on well the software was designed in the first place and the level of reward for successfully finding one, but there will always be exploits.
    Keeping your browser up to date and common sense are the best defence.
