Cooling Seidon 120d (doing things differently)
Discussion in 'Hardware' started by atc95, 6 Jun 2013.
  1. atc95
    atc95 I have the upgrade bug!
    3 Dec 2012
  2. zulu9812
    zulu9812 New Member
    21 Oct 2010
    From what I've read, stacked radiators is somewhat pointless. It's considerably less effective than push+pull fans on one radiator and in this set-up I'm note sure you'd be able to swap out that middle fan. Cooler Master would have been better off with a single, thicker radiator.
  3. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    I'm curious about this. Most stacked radiator setups use standard radiators, which are optimized for the assumption that there'll be minimal airflow restriction on either side, so the fans can just push/pull air through.
    I'd love to see a true comparison between a standard 120mm radiator, this, and a thin 240. ( I highly doubt that setup can match a 60mm thick 240mm radiator. )
