Case Mod - In Progress Self made COSMOS II Clear Panel
Discussion in 'Project Logs' started by arg-ist, 11 Aug 2014.
  1. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    A new version of Clear panel made for my friend.
    MY friend wanted to buy a plexi sidewindow for cosmosII
    It costs 160 USD . and shipping 184 USD (UPS). A great summe.He asked if ı can make his window.
    I had seen a lot of selfmade Windows , but their quality was not sufficiently.
    Max. 5mm plexi or with ugly hinges. Or some hard mods at he case..
    This is original side panel from mnpctech
    He sent the original CosmosII window to me with original hinges
    and I made him a clear sidewindow panel. With original hinges.
    Nothing must be modified at the case.. if he wants he can mount the original door too.
    First the dimensions..next drawing at corel , and laser cut…
    I used 10 mm plexi (original is 12mm thick (it was diffucult to find 12mm plexi in goog quality..)
    This is 10 mm lasercut sidewindow with protection foils.
    The hinges and locking mechanism mounted to the plexi
    I have send the door with post to my friend and this are some photos from the Cosmos II case with the new clear side window ,That he send me… becouse I was wondering result..The is result…
    I have paid for laser cutting and for 10mm clear plexi only .
    Of course a little effort …
    OTHER WORKLOGS
    PlayDoh Silverstone TJ07 - Acrylic tubing
    http://forums.bit-tech.net/showthread.php?t=267324
    SAK SAK 900 D CASE
    http://forums.bit-tech.net/showthread.php?t=271227
    JUMBO CASE
    http://forums.bit-tech.net/showthread.php?t=266554
    TERMINATOR CASE
    http://forums.bit-tech.net/showthread.php?t=267028
    12 Angry Men 900 D Case
    http://forums.bit-tech.net/showthread.php?t=266585
    mmt 900D Case
    http://forums.bit-tech.net/showthread.php?t=266954
    ER36PO Level 10 GT - Acrylic tubing
    http://forums.bit-tech.net/showthread.php?t=269227
    How to make BENCH CASE from an old ATX
    http://forums.bit-tech.net/showthread.php?t=277334
  2. Hyldgaard12
    Hyldgaard12 What's a Dremel?
    24 Jan 2015
    Hey ARG-IST is it possible to get the drawin you made i really want to create a sidepanel like you did my dad working with lasercuters so would be nice with a drawing really hope you can help me :) Best Regards Christian From Denmark ncie work by the way :)
  3. Hukkel
    Hukkel James' minion
    20 Dec 2012
    If I am correct yours is straight and it doesn't have the bend in the panel to follow the lines of the case right?
  4. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Sorry Dude
    It is not a product for sale.
    Becose of this panel I am a PERSONA NON GRATE (unwanted person) by MNPC and and at ModZoo forum. My worklog is delated .
    I do not want to have problems with MNPC.
    Modding is my hobby not my job. I have tried and done...
    Thanks, sorry.
  5. Hukkel
    20 Dec 2012
    Because you wanted to sell them or because you made something you could have bought from them instead?
    The user here is just asking for the drawing.
  6. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Yes Hukkel ,
    it is correct. My acrylic panel is not bended, bu the original MNPC sidepanel is not bended too..
  7. GiantKiwi
    GiantKiwi What's a Dremel?
    6 Jan 2011
    So, if i'm reading this right, they (MNPC) deleted your worklog of this sidepanel on certain forums due to the similarities of their own aftermarket part?
  8. Teelzebub
    27 Nov 2009
    Say what? if that is the case that's out of order :nono:
  9. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    YES.
    and without any explanation ..
    Teelzebub likes this.
  10. Teelzebub
    27 Nov 2009
    I like the one you made better than the one MNPC sell maybe you should take orders for them :thumb:
  11. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Update 14.04.2016
    a new version for my friend.arg-ist
