Senfu Temp Probe Question
Discussion in 'Hardware' started by AW3K, 14 Jan 2002.
  1. AW3K
    AW3K What's a Dremel?
    3 Nov 2001
    will it effect it's acuarcy if i install a plug and socket inline so i can disconnect it from the meter it's self?
    Cheers
    AW3K
  2. Cheese
    Cheese Doc
    6 Oct 2001
    Shouldn't think so... resistance in a plug isn;t much :D
    Cheers,
    r.
  3. AW3K
    3 Nov 2001
    cheers m8
    do you know where i can the sensors cheap?
    Cheers
    AW3K
  4. Cheese
    Cheese Doc
    6 Oct 2001
    try www.farnell.co.uk - they rarely fail to impress me (well apart from in the quality of the website) :)
    Cheers,
    r.
