Senior Project: Revision 1
Discussion in 'Project Logs' started by xc3ll, 31 May 2005.
  1. xc3ll
    xc3ll What's a Dremel?
    31 May 2005
    As a senior project for my HS, I decided to make a computer case. So far I have pretty much finished the design(except for a few details--backplate(dreading that...), and a few constraints left to make...) and I'm gonna start making it VERY soon(100% CNC hehehe), as school is almost over...
    Below are some rendered shots... all I can say is that I really admire macs(from a design point of view)...
  2. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    Those sketches look impressive, I like the sharp curves. Are you planning to use aluminum or what?
  3. xc3ll
    31 May 2005
    i plan to be using a mixture of sheet metal and aluminum... alot of it depends on pricing... I dont wanna spend alot of money, as I'm going 2 college soon...
  4. mobius9
    mobius9 Minimodder
    4 May 2004
    looks pretty interesting, anything special hardware wise?
  5. JavaDog
    JavaDog What's a Dremel?
    13 Mar 2004
    If you are doing this with the help of a CNC mill/router - why do you dread the backplate. Heck, with a machine doing the cutting - that's a peice of cake!
  6. xc3ll
    31 May 2005
    well i made the backplate for all the i/o connectors once already in Inventor(autocad software), and that was just such a pain that I dont wanna do it again(i need 2 cuz i changed the design aroun--***!!)...
    as for special hardware, prolly nothing special... i only made room for 2 HDs and 1 optical drive(i wanted it 2 be small for LAN parties)
  7. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Looking good, would love to see this finished.
  8. JavaDog
    13 Mar 2004
    I use Inventor as well. Excellent software, especially once you figure out some of the tricks to making it do what you want!
  9. xc3ll
    31 May 2005
    yeah, inventor is pretty good, although I've never worked w/sheet metal b4, and its been kinda tricky...
  10. shplade
    shplade What's a Dremel?
    10 Dec 2004
    On inventor can't you just use make the models a standard part instead of using sheet metal? or do you need to use sheet metal for milling?
  11. xc3ll
    31 May 2005
    yeah, theres two different ways to do it... one, you can just do it the regular way as a 3d model(which I prefer), but theres also a special sheetmetal process(which isn't too different, except for a few things).
  12. infered101
    infered101 What's a Dremel?
    30 Oct 2004
    I most have a crappy version of inventor cause my version sucks. It wont install correctly on windows XP it has license problems and i install it on 98 and it has stability problems and will crash in the middle of my design. I was stupid and spent 30 minutes working on a project and didnt save (argh) and it crashed i was MAD. If i could afford it i would get autocad in a heart beat.
  13. xc3ll
    31 May 2005
    Well I'm going to be cutting most of the parts tomorrow(maybe over the weekend) with a plasma CNC cutter... I'll be sure to post some pix!
  14. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Do it damnit! Post pics.
    :~subscribed.
  15. xc3ll
    31 May 2005
    well my project is on hold right now... The CNC plasma cutter I was hoping on using is broken, so I gotta wait quite awhile to get the case made. I'll post an update tho, as soon as I make some progress...
  16. bahgger
    bahgger Minimodder
    13 Apr 2005
    wish my school has cnc cos im doing the same thing :/ (see project nolio) good luck with it! :)
