Music Sennheiser HD650... Nothing will ever be the same.
Discussion in 'General' started by Zinfandel, 17 Sep 2012.
  1. Zinfandel
    Zinfandel Well-Known Member
    2 Aug 2010
    So I tried some of these at Scan today. And now I can't listen to any music ever because it will never sound that good again.
    Basically, this thread is trying to get you to convince me to buy them, because otherwise I can't spend £265 on headphones...
    Tell me I should buy them.
  2. Constructacon
    Constructacon Constructing since 1978
    12 Oct 2004
    Do it. Dooooooo iiiiiiit. Doooooooooooooooooooo iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiittttttttttttt!!!!!
  3. Unicorn
    25 Jul 2006
    I wouldn't ever be without mine. They're like my baby :D
  4. smc8788
    smc8788 ...at least I have chicken
    23 Apr 2009
    The HD650's are great sounding cans if you can withstand the clamping force. I couldn't, and ended up spending £600 on some Beyerdynamic T1's, which quickly lead to spending another £700 on a Violectric V200 amp, then £200 on some Denon D5000's. If you do decide to get the 650's, I can assure you they will just be the start of your obsession :D
  5. faugusztin
    11 Aug 2008
    One thing which is perfect in higher end Sennheisers (read 80€ and higher) is the material of ear cushions... I can use HD555 all day, but HD201 is pain on my ears after a hour or two.
    And if you like them, buy them unless lower priced Sennheisers will do it for you as well :D.
  6. docodine
    docodine killed a guy once
    10 Feb 2007
    Try the HD600 or some used HD580s if you want to maybe save some money with a similar sound signature
  7. aramil
    aramil One does not simply upgrade Forums
    10 Jul 2012
    I have a set of hd600's and they are the dogs........ the 650's are slightly more refined but cost a lot more.
    Although I do run them off a Creek OBH-21SE.
    Sent on my CM10 JB powered i9100 by TapaTalk 2
  8. Zinfandel
    2 Aug 2010
    The thing is, it was off of my phone as well... So I can't even begin to imagine just how good they must sounds from something with a reasonable output...
    Urgh, I am really struggling to justify dropping that much on some cans though...
    What about the 558s? Less than half price, a far more palatable amount to spend... I'll probably just spend all my time sulking thought because they're not the 650s :(.
  9. smc8788
    23 Apr 2009
    The HD600s actually have a quite different sound signature that is more neutral than the HD650's. If you want the more warm, bassy sound of the 650's on a budget I would recommend something more like the Goldring DR150's.
  10. bagman
    bagman Well-Known Member
    18 Apr 2009
    I was the same when I listened to the Grado sr225.
  11. knuck
    knuck Hate your face
    25 Jan 2002
    I personally could never go back to headphones ever again. Even on my PC I use earphones because my head is way too big and my ears always get crushed
    klipsch image s4i <3
    I can wear them all day and just not feel them at all
    The sound is obviously not nearly as good, but I'm not an audiophile so I don't mind :)
  12. Nexxo
    23 Oct 2001
  13. Hopper
    Hopper New Member
    4 Jan 2012
    I have had my Sennheiser HD 650's for nearly 10 years. Yes they are look very tired but they still sound just as good as they did on day one.
    Yes mine have had a couple of new parts (replacement cable & ear cover cushions) but there are lots of places selling spare parts. They were mighty expensive but having them nearly 10 years justifies the price tag
  14. TheCherub
    TheCherub Member
    16 Sep 2007
    I know they come up on a forum I frequent semi frequently second hand, normally for about the £150 mark...
  15. alecamused
    alecamused Member
    22 Apr 2008
    If you find can's you really like, buy em - you won't regret it. You'd buy 2 or 3 cheaper pairs otherwise, you would have spent the same for something you know isn't what you wanted and might even buy them after all.
    Do yourself a favour tough, once you decide on a model, stop looking around for alternatives - you will always find better (as in more expensive) ones you'll want to have.
    And get a headphone amp. :)
  16. TheGreatSatan
    TheGreatSatan Dark Lord of BT!
    5 Aug 2005
    I bought the top of the line Seinnheiser ($200) and wasn't impressed. My Corsiar HS1A's are definitely the best I've ever heard. They were always for gaming, but lately I like using them for music too
  17. TheCherub
    TheCherub Member
    16 Sep 2007
    $200 is way short of top-of the line for Sennheiser. The HD800s are about £1000 ($1600) and they also did a set with a dedicated headphone amp that were if memory serves about $14,000
  18. TheGreatSatan
    5 Aug 2005
    What a waste
  19. TheCherub
    TheCherub Member
    16 Sep 2007
    Have you heard them?
  20. CarlT2001
    CarlT2001 New Member
    23 Jul 2004
    I have always wanted some open backs, but worry about sound leakage. Is it quite noticeable, even at lower volumes?
