sensor mess up
Discussion in 'Hardware' started by v0id, 23 Jun 2002.
  1. v0id
    v0id What's a Dremel?
    2 Mar 2002
    OK - I just got my new EPoX 8K3A+ mobo, and i start it up.... temps on CPU are around 40 degrees steady after installing windows and such... I then install MBM5 and Speedfan, and both say my CPU is at a 90 Deggrees (C) temp... i then reboot, and BIOS says its 40 still..... whats goin on???
  2. jamiesurfs
    jamiesurfs Boom Boom, Cha Cha Cha!
    21 Oct 2001
    Check that they are set up to use the correct sensors for you M'board.
  3. v0id
    2 Mar 2002
    theres a whole bunch of sensors and such.. kinda odd.... used to only have a few on my old mobo... but yeah... i think they were set up correctly..... i dunno.......
  4. Lazy
    Lazy Meow?
    13 Nov 2001
    select each one and see which one gives you a more realistic temp. I get a cpu temp of -127 on one of the mbm ones :)
  5. RTT
    RTT #parp
    12 Mar 2001
    go to the MBM homepage and it'll tell you how to set the sensors up for your mobo :)
  6. v0id
    2 Mar 2002
    got it workin...... thanks guys :)
  7. RTT
    RTT #parp
    12 Mar 2001
  8. v0id
    2 Mar 2002
    Another thing i noticed... My +3.3 is showing a 1.55V.... uhhhh..... not sure how good that is....
    My +5 and +12 are just fine.. 4.95 and 12.04... whats goin on exactly???
  9. RTT
    RTT #parp
    12 Mar 2001
    the 3.3v cant be right @ 1.55v :worried:
    Your bios should tell you voltages
  10. v0id
    2 Mar 2002
    could the puter run w/ the 3.3 @ 1.55???
  11. Impossible
    Impossible What's a Dremel?
    23 Jun 2002
    Heheh, is it running atm, if so, there your answer, its unlikly that your mobo could run at 50% voltage than it asks for.
    Imp
  12. v0id
    2 Mar 2002
    well my guess is that its a mess up then..... cause its runnin like a champ!!!
