Other Serial 232 to USB converters - SOLVED
Discussion in 'Hardware' started by adam_bagpuss, 28 Oct 2010.
  1. adam_bagpuss
    24 Apr 2009
    Im looking for serial 232 to usb converters
    now thats easy you might say but i need one that will be 100% compatible with windows 7 64-bit has anyone used one that works or know someone that has.
    ive seen some around from various shops but a lot have conflicting comments like works a treat on windows 7 64-bit and then another comment says no driver for win7 64-bit !!!
  2. Xlog
    Xlog Minimodder
    16 Dec 2006
    They work fine (the ones that are using FT232 chip at least), but mind you - they are sometimes recognized as Microsoft trackball.
  3. adam_bagpuss
    24 Apr 2009
    no matter ive solved it
    used prolific serial to usb drivers as they are WHQL certified they work on most converters
