Serial-->USB
Discussion in 'Hardware' started by scopEDog, 7 Jun 2002.
  1. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    Hey guys..can't believe england won...anyways, has anyone used one of those serial to usb converters for, lets say, an lcd? If so, which one did you pick up? Thanks!
  2. Lazy
    Lazy Meow?
    13 Nov 2001
    forgot where you get them from but thy cost £30 which was to expensive for me.
  3. GiGo
    GiGo was once a nerd.....
    12 May 2002
    £30 canb't you just use an old USB > PS2 then a PS2 > Serial. Both of these came with mice. Both Trust. Not to sure if this'll work. Worth a go.
  4. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
    I doubt that would work, but one can try.
    Any device acting as a serial device on a USB port will act in funny ways. For example, you will always have to plug it into the same USB port.
  5. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    That's assuming that all the adapters (particularly the PS/2 to USB mouse adapter) has the entire pinout for serial. I think a mouse uses 5 or 6 pinouts and if they don't coorespond with what the LCD uses, could be trouble.. but if you have all of them on hand, doesn't hurt to try.. :D
  6. scopEDog
    scopEDog Minimodder
    5 Mar 2002
  7. Cheese
    Cheese Doc
    6 Oct 2001
  8. Lazy
    Lazy Meow?
    13 Nov 2001
    maybe someone who is could with lcd's could try wiring one up to usb and give us a guide...... (hint hint cheeseman)
  9. Cheese
    Cheese Doc
    6 Oct 2001
    I'm lead to believe it's as simple as plugging the serial plug from the lcd into the convertor, and then the usb plug into your computer... it installs the convertor as a serial port and you're away to play. :)
    r.
  10. Lazy
    Lazy Meow?
    13 Nov 2001
    wouldn't wiring it directly into a usb plug be a lot cheaper than £30?
  11. Cheese
    Cheese Doc
    6 Oct 2001
    lol yeah if you want to write software for it sure... you could get the necessay converting ic yourself and do the wiring yourself, I can't help you with that though.
    Cheers,
    r.
  12. Lazy
    Lazy Meow?
    13 Nov 2001
    just an idea for the adventurous. :D
  13. Cheese
    Cheese Doc
    6 Oct 2001
    Ahh if only you knew what was to come, you wouldn't need to ask for such things :)
    r.
  14. Lazy
    Lazy Meow?
    13 Nov 2001
    ohhhh have you got some thing planned??
  15. Cheese
    Cheese Doc
    6 Oct 2001
    Nope.
    r.
