Networks Serious network help needed
Discussion in 'Hardware' started by Boss_Playa, 14 Oct 2002.
  1. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    What is the laptop make/brand? Your card is capable of 100mBps, but is the laptop?
  2. Boss_Playa
    Boss_Playa What's a Dremel?
    6 Jan 2002
    The Laptop is made by Time (UK based company). The laptop should be able to handle 100mBps.
    Laptop specs
    AMD K6-2 500mhz
    128MB RAM @ 100mhz
    8MB Graphics Card
    12GB Hard Drive
    2xPCMCIA 2x USB.....
    OS - WIN98 SE
  3. Shadowspawn
    1 Jul 2002
    Well, I was hoping for the model number so that I could look at its manual from the manufacturers website - but, nevermind, its moot now.
    Vi-Kata is right. Your NIC in the laptop is capable of 100mBps traffic. The slot its plugged into is not. Check the manual, verify that the slot is indeed a 16 bit slot. If it is, you are stuck with the slower speed where the laptop is concerned...unless Time has released a BIOS patch for it.
  4. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    sorry mang, ive been known to scan thru posts a little too quickly sometimes.. :(
    ndtinker, both specs are right, one is 568a and the other 568b, use one of those on each end to make a crossover cable.. :)
    -scoob8000
  5. Boss_Playa
    6 Jan 2002
    Here is a little update on the problem...
    I contacted Belkin on Friday and was told to check a few bits in my device manager and what the technician told me was that I have a CardBus controller so I would need a CardBus NIC (32bit). He told me to return the NIC where I purchased it and get the CardBus NIC.
    As I have had the card for a month I told him that EBuyer would not take it back unless it was faulty, so he pondered for a while and told me that if I send it back to Belkin he would swap it for the CardBus NIC :rock: :clap: :rock:
  6. vi-kata
    vi-kata What's a Dremel?
    27 Jan 2002
    Scoob- no worries man :)
    Boss - what a blindingly good result, that's fantastic service from Belkin. Excellent :clap: :clap: :clap:
    Kata
  7. scoob8000
    17 Feb 2002
    i dont own anything from belkin other than a printer cable, but i'll add them to my list of good customer service.. :)
    -scoob8000
