Windows Serious XP problems
Discussion in 'Software' started by pranks7er, 2 Jun 2005.
  1. pranks7er
    pranks7er mange tout
    25 Dec 2002
    Ok my computer the XP home, it hangs on the windows startup splash screen (the windows xp bit with the wee blue band goin across) it does this quiet frequently only way i can fix it is reformat the partition im fed up havin to do this what shud i check to try and source the problem is it hardware or software
  2. Dngrsone
    Dngrsone What's a Dremel?
    17 Feb 2005
    Does it start in safe mode? If so, then take a look at the ntbtlog.txt file and see what the last successful file load and first unsuccessful one are and post that here.
  3. penski
    penski BodMod
    29 Aug 2002
    Start in safe mode - it'll show you where it is hanging.
    Failing that, 0870 60 10 100, option 3, option 1
    *n
  4. pranks7er
    25 Dec 2002
    keyboard wont work during post cant select safe mode
  5. pranks7er
    25 Dec 2002
    the log the problem happened again
    Microsoft (R) Windows (R) Version 5.1 (Build 2600)
    6 14 2005 21:31:08.500
    Loaded driver \WINDOWS\system32\ntoskrnl.exe
    Loaded driver \WINDOWS\system32\hal.dll
    Loaded driver \WINDOWS\system32\KDCOM.DLL
    Loaded driver \WINDOWS\system32\BOOTVID.dll
    Loaded driver ACPI.sys
    Loaded driver \WINDOWS\System32\DRIVERS\WMILIB.SYS
    Loaded driver pci.sys
    Loaded driver isapnp.sys
    Loaded driver pciide.sys
    Loaded driver \WINDOWS\System32\DRIVERS\PCIIDEX.SYS
    Loaded driver MountMgr.sys
    Loaded driver ftdisk.sys
    Loaded driver PartMgr.sys
    Loaded driver VolSnap.sys
    Loaded driver atapi.sys
    Loaded driver disk.sys
    Loaded driver \WINDOWS\System32\DRIVERS\CLASSPNP.SYS
    Loaded driver sr.sys
    Loaded driver KSecDD.sys
    Loaded driver Ntfs.sys
    Loaded driver NDIS.sys
    Loaded driver Teefer.sys
    Loaded driver sisagp.sys
    Loaded driver Mup.sys
    Did not load driver Advanced Configuration and Power Interface (ACPI) PC
    Did not load driver Audio Codecs
    Did not load driver Legacy Audio Drivers
    Did not load driver Media Control Devices
    Did not load driver Legacy Video Capture Devices
    Did not load driver Video Codecs
    Did not load driver Processor
    Did not load driver SiS 7018 Audio Driver
    Did not load driver Crystal SoundFusion(tm) CS4281 WDM Audio
    Did not load driver RADEON 7000 SERIES
    Did not load driver Communications Port
    Did not load driver Printer Port
    Did not load driver Standard Game Port
    Did not load driver MPU-401 Compatible MIDI Device
  6. Dngrsone
    17 Feb 2005
    Okay, ACPI is hanging up. Check your BIOS power settings. Try turning the conservation options off and see if that improves things.
    If you have USB devices plugged in, then try unplugging them and see if that does anything.
    Also known causes are video card/driver (I don't think that's the case here) and corrupted drivers (try chkdsk /p).
    Let us know what, if anything, helped.
  7. pranks7er
    25 Dec 2002
    changed usb keyboard to a ps2 and it worked
  8. Dngrsone
    17 Feb 2005
    Great! :rock:
