Build Advice Server Cases
Discussion in 'Hardware' started by I-E-D, 3 Jun 2009.
  1. I-E-D
    I-E-D Minimodder
    28 May 2009
    Hi all,
    I'm looking for a case for a Windows Home Server, that has 3 3.5" HDD spaces, and space for at least an ATX sized Motherboard.
    Also, i need advice on the Motherboard, CPU and PSU (like what wattage?)
    Cheers
    I-E-D
  2. Krikkit
    21 Jan 2003
    The buyer's guide on the main site is a good place to start. :)
    For only 3 HDD's you don't need a "server" case, nearly any reasonably-sized case will take a minimum of 4 HDD's, often a lot more if you use a drive-bay converter.
    A server doesn't need to be powerful either, something like an Athlon XP or A64 would do.
  3. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    All depends on budget/main uses etc.
    Give that information and people will be better able to help you get what you want.
  4. I-E-D
    I-E-D Minimodder
    28 May 2009
    I only said server case, because that's all i could think of.
    I realise that the CPU doesn't have to be powerful, and was wondering whether i should go with Intel or AMD?
    I'm going to get a 1.5TB HDD and 2/4GB of Ram, probally 2.
    Would a 350w PSU be good enough?
    Slizza, what more can i give apart from budget which is £300/400
  5. I-E-D
    I-E-D Minimodder
    28 May 2009
    Also, where can i get a manufactorers edition of the Windows Home Server OS?
  6. Krikkit
    21 Jan 2003
    What is it going to be used for? 2GB of RAM is far too much just for a fileserver.
  7. rOBvAN
    rOBvAN What's a Dremel?
    23 Apr 2009
    For a home server anything will do. Any case will do from ebuyer, most of the sub £20.00 ones have 5x3.5" drives. I'd go for a second hand CPU from ebay as it really doesn't have to be powerful at all. You'll probably be able to find a very cheap Pentium 4 or Celeron (LGA775) on ebay that will do the trick. 1gb of RAM is more than enough for Windows Home Server and so is a 350W PSU.
    I have Windows Home Server running on a Pentium 4 (2.8ghz), 1gb DDR2 533mhz and a 350W PSU with about 6 different hard disks and it runs fine as a file server.
  8. I-E-D
    I-E-D Minimodder
    28 May 2009
    Cool, thanks. I also plan to attach 2 printers (one black and white laser and one all in one colour), does that mean i'll have to get more ram? And maybe a bit of remote access, i dunno.
    Also, if i plan to (maybe) use it as a gaming server as well, do i need to do anything differently?
    Once i have a shopping list, i'll post it up, and tell me what you think please?
  9. I-E-D
    I-E-D Minimodder
    28 May 2009
    Case
    PSU
    RAM
    CPU
    HDD
    Motherboard
    I'll borrow a GPU and Disk Drive from the family's existing machine, or force my dad to buy me a GTX 275 and a Bluray drive :)
  10. I-E-D
    I-E-D Minimodder
    28 May 2009
    Bump?
  11. GiGo
    GiGo was once a nerd.....
    12 May 2002
    Honestly for what your planning on doing you don't need anything fancy. I've started to put put my home network in order.
    One PC as a file server w/6xHDDS an AMD 3800 64 with XP Pro w/2 GB of RAM. Works a treat, make sure you have a gigabit network switch/router, you'll find it a lot faster for video playback.
    Regards
    GiGo
  12. mooseguy
    mooseguy Crazy Moose
    17 Oct 2008
    That list will work fine, and give you a pretty beefy server that'll do nearly anything.
  13. I-E-D
    I-E-D Minimodder
    28 May 2009
    Cheers, will it be able to host a game like Crysis?
  14. mooseguy
    17 Oct 2008
    With an E5200, certainly. It's not like you're actually running it, graphics and all :D
  15. I-E-D
    I-E-D Minimodder
    28 May 2009
    Nice, thanks everyone.
