Modding Server Cube
Discussion in 'Modding' started by khendar, 9 Jun 2004.
  1. khendar
    khendar What's a Dremel?
    25 May 2004
    Yes yes I know what you are thinking another boring cube pc. However I think this one is a little different.
    Behold... (click image for a slightly larger version)
    Three motherboards, three power supplies, 6+ hard drives (not added yet), 8 12mm fans. All in a 40cm cube. Watercooling a possibility though doubtful. Unsure of construction materials, either steel, alum or acrylic. Hard drives will be mounted in a rack directly behind the front intake fans.
    [BTW: I am by no means planning this as a definite project. I am simply toying with ideas and wondering what will work and what wont]
    What do you guys think ?
  2. noobidoo
    noobidoo What's a Dremel?
    8 Jun 2004
    well i have made sketcht a cube computer my self i kan show it you want to se it
    :hip:
  3. evilstriker
    evilstriker What's a Dremel?
    29 May 2004
    you gonna fit 3motherboard??? lol you crazy
    the hell you gonna put 4motherboard in a cube for??? hehe im just kidding ya
    it is gonna be like 3 p4 4.0Ghz or maybe 3 AMD 3000+??? :)
    where your getting all the money to buy all that stuff?? ehhee
  4. khendar
    25 May 2004
    Sure why not...Just keep the size down... :worried:
  5. khendar
    25 May 2004
    ROFL...Read the last bit of my first post. I'm just tossing around ideas.
    I'd dearly like to build a high end server, as a render farm, webserver, file server, etc. The cheapest way to do it ( I think ) is not to go all out on a dual xeon server or something, but to build a cluster of "regular" pc's.
  6. noobidoo
    8 Jun 2004
  7. noobidoo
    8 Jun 2004
    some thing like that woud be nice woudn't it :jawdrop: :naughty: :dremel:
  8. khendar
    25 May 2004
    Nice design. Seems to have quite a bit of wasted space though. You could save some by making the motherboard section smaller...but then it wouldn't be a cube would it ? :D
    Might also want to get some ventilation to those hard drives. They are kinda tucked away up in the top there and might get warm.
  9. noobidoo
    8 Jun 2004
    it's designed for wather cooling so if you want to put a tank i there it will fitt
  10. khendar
    25 May 2004
    Ahh well there you go then. Water cooling should fit in there easily.
  11. Jedi
    Jedi What's a Dremel?
    16 May 2004
    woah, this case would be a beast :D :D . If u win the lottery anytime soon then maybe 3 * quad opterons :rock:
  12. khendar
    25 May 2004
    Here's hoping :D
    No one else has any ideas ??? Perhaps on how to watercool the beast ?
  13. lunix_user
    lunix_user What's a Dremel?
    31 May 2004
    WOW.
    3 mobos?
    nice idea!
    anyway, for the server os you wont dream about using windblows, right?
    linux for ever!
  14. khendar
    25 May 2004
    Nah Linux for the server portion of it anyway. However I will have windows on there as well, seeing as I intend to use it as a render farm and game machine. Can't do that in linux :p
    Trouble is linux is no good if you are doing any kind of multimedia work. There are no versions of Macromedia Products on it, no decent photo or video editing software, no 3D packages. Plus getting games to work properly is a pain in the arse. So until the Linux community get off their arses, make it easier for the common man to use, and get some 3rd party software support, Windows is the only choice for Multimedia (unless you count Macs, but lets not got there )
