Networks Server - NIC Teaming
Discussion in 'Hardware' started by cannon, 2 Nov 2005.
  1. cannon
    cannon What's a Dremel?
    15 Jan 2004
    Ive got an older HP server that at work we are using as a utility server.
    In the past it has had teaming set up but has always been broken.
    Ive just updated the drivers for both NICS and the HP config software but still getting this issue (see screen shot) when I try to create a new team with the two cards.
    Any suggestions on how to get around this? if i can....
    Thanks in advance!
    Paul
  2. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    Have you tried older driver versions?
  3. Atomic
    Atomic Gerwaff
    6 May 2002
    Do you not have to use identical pairs of NICs for teaming?
  4. cannon
    15 Jan 2004
    We tried the original drivers and drivers that were a couple of revisions old and still no go.
    Atomic - we have 7 other hp servers all of which are teaming with different nics so im pretty sure this is not the issue.
  5. :: Phat ::
    :: Phat :: Oooh shakalaka!
    7 Jun 2002
    It could be an issue with these paticular NIC's, do any of the other servers team with these two cards? (are they two cards, or is one an on board?) you could try changing out a NIC from one of the other servers (as long as they're different?)
  6. trigger
    trigger Procrastinator
    22 Mar 2004
    You don't have Jumbo Frames enabled on the gigabit NIC do you? If so that may be confusing the setup. I've never setup a team with a 10/100 and a gigabit connection, only two 10/100 or two gigabits, so I'm not sure whether that works.
  7. cannon
    15 Jan 2004
    The 10/100 is onboard and the gigabit is addin.
    with the other servers all cards are gigabit cards, they just dont all have gigabit network blades to plug into, so maybe its just that....
    No idea - its working with no teaming - just like that added bit of security knowing it will always be contactable on one addres..
    Thanks for your help
