Development Server-Side CSS Theme Selector
Discussion in 'Software' started by OneSeventeen, 13 Jun 2003.
  1. OneSeventeen
    OneSeventeen Oooh Shiny!
    3 Apr 2002
    I'm going to try and make my site all cool and customizable like linear's, but I'd prefer to keep it server-side for now. Linear did his with javascript and php acording to his post on another forum.
    So anyway, is there a simple way to get this done? I'd love to go a step further and allow people to select an external stylesheet, and use something similar to linear's script to edit whichever style they chose.
    Basically I'd like to choose a completely different style sheet for the layout, and use the selector to choose the colour theme. I'd also like to let it change a few images as well, if possible, so the site still "matches".
  2. linear
    linear Minimodder
    5 Oct 2001
  3. OneSeventeen
    3 Apr 2002
    :rock:
    Thanks once again, linear!
  4. Sid
    Sid Banned
    13 Mar 2002
    I think I am going to add some sort of thing to be able to increase or decrease font size to a site I'm doing at the moment. The site is for my church and many of the people are elderly so may have poorer eyesight, so increasing the font size would be nice.
    I'll probably try to do it server side too, because I don't want to rely on javascript because there are always one or two people with it turned off.
    Haven't really read that site properly yet but it looks like it may be quite a big help.
  5. OneSeventeen
    3 Apr 2002
    The only problem with the csszengarden is that it uses address-bar specified stuff.. so I'm not sure how to make this a more permanent view for users. Ideally I'd like to have people sign in to my site and be able to customize it to their liking. Mainly because I will probably eventually make a nice page for people to use as their startpage. Bringing them news and calendar features, as well as web-based mail eventually.
    Sort of a small-scale msn.com, so when I build someone a PC or a web page or whatever, I can set my page to their startup page.
    Any ideas how to do this based on cookies for now? Or would that just basically be a mixture of their script and linear's?
    On Second thought, anyone know good books on web programming?
    I've got PHP 4.3.2, ASP, ColdFusion Server, MySQL, and ActivePerl running on IIS 5, are there any books with all of this in there?! :confused:
  6. linear
    linear Minimodder
    5 Oct 2001
    Well, you know the four ways to get a variable into a PHP script, yeah? So you don't wanna use GET or POST, and maybe you don't wanna use a SESSION, so what's left?
  7. Sid
    Sid Banned
    13 Mar 2002
    coooookehhhhhhh!!!!!!!
    lol, am i right actually. I had to think about that. :hehe:
  8. OneSeventeen
    3 Apr 2002
    Okay, I finally did a bit of learning instead of begging, and this is what I've come up with:
    you can go to www.woventhorns.com/learning/index.php and it will load the default style, or you can type in www.woventhorns.com/learning/index.php?style=print to see the print style.
    I have only done this one page, and none of the links work. I may later on figure out how to use cookies along with this... maybe a post instead of a get, implemented by a cookie? Is this possible? or can post only come from forms?
    Either way, I'm actually learning php finally! And it wasn't as hard as I thought it would be!
  9. Shad0r
    Shad0r What's a Dremel?
    9 Mar 2002
    Cookies are the way to go...
    Code:
      Response.Cookies("mycookie")("css") = 1
      Response.Cookies("mycookie").Expires = DateAdd("m",6,Now())
      If Request.Cookies("mycookie").Haskeys then
        usercss = Request.Cookies("mycookie")("css")
      Else
        usercss = 1
      End if
    ...in ASP, natch :cooldude:
  10. OneSeventeen
    3 Apr 2002
    I'm looking more for PHP...
    I'm running IIS and have heard there are problems with setcookie() and IIS, but this could easily be solved by installing php as an ISAPI filter... unfortunately the only instructions I've found involved using php4isapi.dll in the sapi subfolder of my PHP folder... I just downloaded the latest version of php and installed it and it had no sapi subfolder, much less a php4isapi.dll :(
    Back to the drawing board...
  11. OneSeventeen
    3 Apr 2002
    Okay, I wasn't thinking, and I've changed to using ISAPI filters. I relied on the windows installer last time, so I uninstalled and went through a manual installation instead.
    I still can't get the cookie to work though. I think I need to mess with headers or something?
    help?
    oh yeah, the page in question is at http://www.woventhorns.com/learning/
