Set up for Hard Drives
Discussion in 'Hardware' started by Gooey_GUI, 7 Dec 2004.
  1. Gooey_GUI
    Gooey_GUI Wanted: Red Shirts
    3 Dec 2002
    I want to install the Maxtor as the boot drive and the Raptors in RAID 0 for large video files. Do I need to have two total arrays? Can I have a single drive on the first port of the first pair of ports then the array on second pair of ports?
    (1) Maxtor MaXLine III - 7B300S0 - 300 GB SATA
    (2) WD - Raptors - 74 GB
    TIA
  2. webbyman
    webbyman Hax.
    7 Oct 2004
    your operating system would proberly boot alot faster if you just used about an 8gb partision of one of the raptor hdd, but i dont know if you give a monkey, and might be a little confusing :hehe:
    :hehe:
  3. Gooey_GUI
    3 Dec 2002
    The MaxLine is an NCQ drive that I will use with an SLI board when they arrive. It will boot the OS much faster than the Raptor. It's also going to be used with a database which will also be faster with random files.
  4. v0id
    v0id What's a Dremel?
    2 Mar 2002
    Even with a MaxLine with NCQ, I doubt you will be booting MUCH faster than if you used the raptors to boot. I actually think the raptors would take the cake here.
  5. Gooey_GUI
    3 Dec 2002
    The original question is not being answered. I'm not asking which should have the OS. I'm asking about the setup as proposed. I don't want RAID 0 for booting with.
  6. kilobyte
    kilobyte What's a Dremel?
    21 Jan 2004
    if you are doing a raid 0 with 1 300gig and a 74 gig drive you are losing over 200 gig of space there just to know u know (or am i reading this post wrong)
  7. Gooey_GUI
    3 Dec 2002
    It's 2 Raptors with RAID 0 and that's secondary to running a single Maxtor as the boot drive.
    Hopefully that's clear by now. If I must run 4 drives then the answer would be that I must use 2 Maxtors in RAID 1, then run 2 Raptors in RAID 0. I'm trying to ask if I can use three drives not four.
    :wallbash:
  8. JuMpErFLY
    JuMpErFLY Minimodder
    13 Mar 2003
    yes you can
  9. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    yes, its completely possible. just seems that for people, its more fun to debate hard drives than to answer questions :duh:
    [/bitchyness]
    anyway, no you shouldnt have any problem at all setting up 2 hdd's in a Raid 0 and one standalone.
  10. Jackal
    Jackal What's a Dremel?
    8 Dec 2004
    as has been said, it will work fine
