Cooling Setting up my first WC system.
Discussion in 'Hardware' started by phoeneous, 21 Jan 2005.
  1. phoeneous
    phoeneous What's a Dremel?
    16 Aug 2004
    Okay, this will be my first time setting up a WC system. I want to keep it simple so I will only be cooling my CPU!
    These are the parts I have chosen, tell me what you think.
    CPU Block - PolarFLO TT (2 x 1/2" barbs)
    Radiator - Black Ice Extreme (120mm w/ 1/2" barb fittings)
    Radiator Fan - Coolermaster UV Blue 120mm
    Resevoir - Tundra (Dual 3.5" bay)
    Tubing - PrimoFlex PVC UV Blue (1/2" ID)
    Pump - PolarFLO TT 350 (12v)
    Am I forgetting anything?
  2. Airmack
    Airmack What's a Dremel?
    2 Jan 2005
    I don't like that res. and the pump might not be enough for your cpu block.
  3. mightynimrod
    mightynimrod What's a Dremel?
    7 Jan 2004
    Sounds ok, your kit is your own personal preference......
    Should be enough for cooling your cpu alone, thats the thing with modilar watercooling, you can add to it with different components as you go along and feel more confident with it.
  4. DanMcr
    DanMcr What's a Dremel?
    27 Jul 2004
    Doesnt that pump have 3/8" fittings?? You will need to use adapters if you buy it, but your better of trying to keep everything 1/2".
  5. Risky
    Risky Modder
    10 Sep 2001
    I thought that pump would good for most setups:
    Oh and you better convert those images to links or host them yourself.
  6. phoeneous
    16 Aug 2004
    Why?
  7. phoeneous
    16 Aug 2004
    If Im only cooling the CPU, is 1/2" ID tubing overkill?
  8. fivecheebs
    fivecheebs Dont panic!
    19 Feb 2003
    Its against the rules .... stealing bandwidth is bad mmkay!
    Edit: added picture, because it felt appropriate. :D (Don't worry, I'm hosting it) --Nexxo
  9. buchans
    buchans What's a Dremel?
    28 Jun 2004
    that pump is enough for ANY setups, I have one -- very impressed! amost totaly quite and no heat!! for the first time ever I can close my case without overheating!! its the first real PC pump I've seen.
    its has 3/8" fittings but I just put some 3/8" tube (about 1" on and put some 1/2" ID over it - works fine)
  10. BlackDiamond
    BlackDiamond What's a Dremel?
    7 Sep 2004
    Looks OK, but as other people said the pump barbs are 3/8 and everything else is 1/2. I also agree about the res - the acrylic bayres ones are not recommended.
    One more thing, I would go with a block that has more clearance around the barbs - swiftech 6000/6002 - putting clamps may not be easy.
  11. phoeneous
    16 Aug 2004
  12. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    No, it's not overkill. You're setup seems fine to me mate ;)
  13. pre
    pre Minimodder
    24 May 2004
    That pump is very good - particularly for size. It has an astounding amount of head thus pumps through a lot of restriction even if it is natively 3/8".
  14. Risky
    Risky Modder
    10 Sep 2001
    No more so than others. The C-Systems pump takes 1/4NPT thread so there's restriction there too.
    However it is possible to make a new housing for the pump to suit. Watercool.de do one in plexi, but thats G1/4 thread
  15. Nexxo
    23 Oct 2001
    Alternatively you could go with 3/8" ID tubing. There really is not that much difference compared to 1/2" ID tubing.
  16. Risky
    Risky Modder
    10 Sep 2001
    Was it really true that the first guy who posted that view on procooling was found under a bridge hung by a lenght of Tygon? :naughty:
  17. phoeneous
    16 Aug 2004
    3/8" it is. Probably much cheaper too.
