Setting up net
Discussion in 'Tech Support' started by Gaunt1et, 30 Jun 2007.
  1. Gaunt1et
    Gaunt1et What's a Dremel?
    30 Jun 2007
    Hey,
    OK heres my problem.
    I want to set up the internet on my laptop in my study (where there is a phone line) but I have a wireless modem plugged in at the other side of the house not far from my main pc (which uses the wireless card because there is no phone line near it).
    The wireless does not reach the laptop in the study but there is a phone line next to it. Is there a way that I can use that phone line to connect to the modem at the other end of the house? Heres a crappy drawing of it.
    Please be detailed in your answer.
  2. culley
    culley What's a Dremel?
    12 Jul 2006
    Put the modem next to the phone and connect it to the PC with an ethernet cable, buy a repeater which boost's the signal strength or buy a better router, maybe one of those 802.11n routers there made for sending hi-def content around the house.
  3. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    Alternatively, Ethernet over power (homeplug stuff) should also work :)
  4. mrlanrat
    mrlanrat What's a Dremel?
    11 May 2007
    They also have that to send Ethernet over phone lines. i know most 2wire routers have that ability built in. and netgear sold (no longer) adapters to do this.
  5. DougEdey
    5 Jul 2005
    That's called ADSL. Or the internet.
  6. mrlanrat
    11 May 2007
    No, I have dsl, and they both use the same concept but one is use for the internet and the other is used for lan.
  7. mrlanrat
    11 May 2007
  8. Krikkit
    21 Jan 2003
    Another option is the mains-version of that phone-line jobby - much more versatile too. :)
  9. Golygus
    Golygus Minimodder
    9 Oct 2003
  10. g3n3tiX
    g3n3tiX Minimodder
    3 Jun 2006
    Or a better antenna/directional one.
    Even a cantenna.
  11. Sam0r
    Sam0r It's been a while
    24 Jun 2005
    I have a feeling he's scratching his head saying "What?!" now.
    Anyway I'll add to it.
    You can buy a cheap wireless access point and set it up to be a relay. There is usually a setting somewhere called WDS (Wireless Distribution System), and the new access point will connect to the old one and relay the signal to your laptop.
    This works really really well provided the relay is close enough to the original access point to at least get a good signal (access points seem to get a better reception than clients anyway).
    How do I know this? Well, I used to steal internet from a guy across the road while I was switching from cable to adsl2+. And before anyone whacks me with the moral stick, I asked him and he said he's fine with it as long as I set up encryption on it after I'm done :)
