Sff - Server
Discussion in 'Hardware' started by dhutch, 10 Oct 2003.
SFF - server
  1. Yeah go for it - will be cool
    27 vote(s)
    79.4%
  2. Indecisive
    2 vote(s)
    5.9%
  3. a SFF server - no way!!!! - rubbish idea
    5 vote(s)
    14.7%
  1. dhutch
    dhutch Banned
    10 Apr 2003
    my dad is proposing we build a SFF (small form factor) file server
    that will stay on 24/7 (unlike our other 2 pcs) and will firstly be a file server and hold all our files (work etc)
    I this at all sensable??
    a SFF server :confused:
    ne way - see what you think
    ps if you think :rock: the post some ideas for componets - bearing in mind it has to be cheap ie under£300 (not in monter etc) and its gota be quite if not silent
  2. Guest-16
    Guest-16 Guest
    Get a shuttle - easy as anything else.
    Personally, if its always on, then get an intel chipset and an intel cpu: itll be the hardest bugger to crash. Whack in 2 250gig harddisks and a cheap CDRW and you're sorted.
  3. Yo-DUH_87
    Yo-DUH_87 Who you calling tiny?
    6 Mar 2002
    You would do well to listen to the man ;)
    You planning on running Winblows on it or a flavor of Linux?
  4. dhutch
    dhutch Banned
    10 Apr 2003
    urrmm im not sure
    id like to think id run linux
    but i dont know which "flavor" - bearing in mind i have only ever used windows befoe - i might just us win 2k
  5. Yo-DUH_87
    6 Mar 2002
    *ahem
    http://www.e-smith.org
    You can turn it into quite the decent web/file/email/whatever server quite easily using E-Smith SME server, I have a dedicated mailserver and a seprate dedicated fileserver set up in my bedroom, no sweat (well, having 2 extra computers running in my room does make me sweat profusely, but you get the idea ;) ).
  6. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    If you havent used linux at all before, wouldnt it be easier to just set up Win2003 or something similar ?
  7. Carbon
    Carbon Banned
    8 Jan 2003
    i presonally use a compaq sff as a games server and it also is my firewall. pII 350 or 400, 128mb ram and 3nic's :blah: windows xp.
  8. Mister_Tad
    27 Dec 2002
    for me it just seems wrong to have a server that isnt huge
    just my opinion though i guess
  9. Carbon
    Carbon Banned
    8 Jan 2003
    i used to think like that too, buti have an 8 gig drive in mine ( i know its not huge, but it does the job) but i needed a silent server solution and i managed to *cough*aquire*cough* a SFF :D
  10. sinizterguy
    25 Jul 2002
    :eeek:
    What do you need 3 NICs for ?
    I need to set up a file and print server at my place. Also can be used as a kazaa downloader.
  11. Guest-16
    Guest-16 Guest
    smoothwall? switch? router?
  12. Carbon
    Carbon Banned
    8 Jan 2003
    i use 3 nics for....
    1=modem
    2=my pc
    3=bro's pc
    i share the net using that server its also my firewall.
    i have to use crossover cables as i havnt got a hub and i started off with a cross over kit and ive just expanded :D
  13. Fronzel
    Fronzel What's a Dremel?
    9 Mar 2002
    I have an SN41G as my server/router/firewall/roommates drink holder thingy.
    It is on all the time. I have the built in NIC to talk to the ISDN modem and 802.11b to talk to the other networks around the house.
    I use Win2K. I reached that decision after about three months of trying to get Linux to see the wireless card properly.
  14. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    Good idea but if you are not running morrored raid or keep any other data backups if your HDD fails... BYE BYE files!
  15. dhutch
    dhutch Banned
    10 Apr 2003
    yeah well ill just back it up onto one of my other computers
    as for raid - no
  16. MR BUNGLE
    MR BUNGLE Shoddymodder
    19 May 2003
    Yeah dude... sounds like a Via Epia / Mini ITX board might be up your street....
    These things seem to be great as file servers etc.... (from what I see on www.mini-itx.com)
    - Though it would be nice, I'm not convinced you really need the power of a Shuttle, nor that it would fall within your budget...?
    nice
  17. dhutch
    dhutch Banned
    10 Apr 2003
    yeah yeah yeah
    thats what i though - no shuttle cos its a rip off
  18. Carbon
    Carbon Banned
    8 Jan 2003
    you can get a pIII sff from ebay.co.uk for £100 or so.
  19. Guest-16
    Guest-16 Guest
    SK41G - £135
    Duron 1.6 = £30
    Its actually cheaper for a shuttle.
  20. dhutch
    dhutch Banned
    10 Apr 2003
    I thought i might go for:
    MOBO:a mini-itx m-board (via epia 800) with 800MHzCPU for £76.38
    HDD:Maxtor DM+9 120 £78
    CASE:cubid 2688
    for £61
    265mb PC133 ram (£41)
    a 60w dc-dc PSU
    and use my bootable flash drive to install the OS from
    ps can you fit win2k on 64mb?
    :idea:
    any way - what do u think?
