Shadow Box CORSAIR MOTM Oct. 05! (Finished July 26, 2005)
Discussion in 'Project Logs' started by Vazzini42, 9 Jun 2005.
  1. Cyberbob:-)
    Cyberbob:-) Minimodder
    16 Jun 2002
    Is that a good motherboard then for Video playback and DVD's??
    Thinking about building something like it...Nice little case where did you get that from?
    Can't wait to see it progress....Looking mate.. :D
  2. Vazzini42
    Vazzini42 What's a Dremel?
    16 Apr 2004
    The mobo seems to be designed to be used as a media PC. I haven't got it up and running yet to test anything out, so I can't give firsthand experience but it should have no problem with anythng you throw at it as a media PC.
    The box is technically a picture frame. I got it from a place called Michael's here in Texas, but you should be able to find them at any arts and crafts stores that sell frames.
    Vazz
  3. AbsoluteModder
    AbsoluteModder What's a Dremel?
    24 Jul 2004
    umm
    looks full of potential, good so far :thumb:
    a little question: why do you install the HD in a mobile device?
  4. Vazzini42
    16 Apr 2004
    I was waiting for someone to ask that :)
    I am planning on using the aluminum cover as a billboard. The HD will not be using the USB on the HD case. It will be modded and will be connected using IDE. Basically the cover makes the HD look prettier without polishing the HD itself and gives me some clean advertising space. :D
    Vazz
  5. Vazzini42
    16 Apr 2004
    Wewt, chugging along on this project nicely.
    Today I chopped out a hole for the Aerogate II to reside and intalled it. :dremel:
    Dry fit:
    Installed: (bent the aluminum at a 90 degree angle on one side and screwed it into the box itself) :D
    Cleaning up the exterior and permanently attatching with JB Weld: (focus is a little goofy, sorry)
    Comments, suggestions, questions always appreciated. :D
    Vazz
  6. Jokkocze
    Jokkocze What's a Dremel?
    16 Dec 2004
    paint it ;)
  7. Firehed
    15 Feb 2004
    woah, what's that big yellow thing with the diamond plate in the background of the first pic?
  8. Vazzini42
    16 Apr 2004
    click the link in my sig firehed :D
    Jokkocze: All in due time my friend :D
  9. Avner
    Avner What's a Dremel?
    19 Sep 2003
    very good job !
    I like EPIA's :)
  10. Vazzini42
    16 Apr 2004
    Thanks for all the kind words :rock:
    I did a bit more work this evening. I installed the 3 fan air intake in the same fasion as the aerogate II. I will try to make both blend in with the side on the case with filler putty so they looke pro.
    Pics:
    I hope these pics give you a better idea of how it all will work. :D
    Mod on!
    Vazz
  11. Xhiz
    Xhiz What's a Dremel?
    28 Oct 2004
    Hey this is looking pritty, can't wait to see more :thumb:
  12. Vazzini42
    16 Apr 2004
    did a little bondo work today and a little bit of paint:
    Vazz
  13. frodo
    frodo What's a Dremel?
    1 Nov 2003
    Looking smooth mate
    keep it up, cant wait to see this finished!
  14. Sva4g3&*
    Sva4g3&* What's a Dremel?
    15 Jun 2004
    I like this very, very much, and I think I'm going to do something like this very soon. Where did you pick up that power supply? I've found one website and they're like $50, is that a reasonable price for them? They also have a 200w one which looks a little more promising if I was going to have a video card and such.
    -Rob
  15. Vazzini42
    16 Apr 2004
    its a travla 90w DC-DC convertor (i havent recieved it yet and we might be going with a different version)
    best place in the US I have found was dc2dc.com
    but if you go to the travla website they have a where to buy section.
    $50 seems to be a great price and from what I understand, Travla is a good line of products.
    I would suggest figuring out how much each item draws in your plan and totaling it all up. (HD, mobo, fans, kb, mouse, few extra usb thingies, etc)
    Mine came out to roughly 70W, but going with the 90W version gives me some room to play.
    Hope that helps :D
    Vazz
    EDIT: Sva4g3&*: Power Supply calculator
  16. LOTTARO
    LOTTARO What's a Dremel?
    1 Jul 2005
    Very sweet!!!
    The case is a old picture frame?
  17. Vazzini42
    16 Apr 2004
    I bought the frame new, but yes it is a shadow box picture frame meant for 3d things. (figurines, collectables, war medals, that kinda stuff)
  18. Sva4g3&*
    15 Jun 2004
    Hmm, alright, anyone know where I would find how much power certain things would draw?
    -Rob
  19. Arkuden
    Arkuden mow?
    9 Jul 2004
    oh that looks sweet. I cant wait to see the final update. Very nice work so far! :clap: :clap:
  20. ginx
    ginx What's a Dremel?
    1 Sep 2004
    that is one of the sexiest motherboards i have ever seen, i would really love to see this in person when its completed.
