Apple Sharing a wired network connection with iPhone
Discussion in 'Software' started by Cupboard, 12 Jan 2008.
  1. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    I was wondering if anyone knew if it was possible to share a wired (ethernet) network connection with an iPhone over Wifi? It seems to be possible using a Mac, but all other suggestions rely on using a router, which I don't have access to.
    I have in the past bridged a wireless connection with wired, in order to let a computer without wireless connect to a wireless network, but essentially I am trying to do the opposite of that and it doesn't seem to be working. :confused:
  2. Cupboard
    30 Jan 2007
    Anyone?
  3. crazybob
    crazybob Voice of Reason
    21 Oct 2004
    What operating system are you using? Your sig shows a handmade system (most likely Windows) but you mention a Mac. In Windows XP, if the computer is connected to a wired network and the wireless interface is disconnected, then bridging the two connections will turn the computer into a wireless access point. However, it won't always work because some wireless drivers get confused. I tried this on my laptop once and it actually destroyed the wireless drivers, requiring me to reinstall them.
  4. Cupboard
    30 Jan 2007
    I am trying to do it using either Windows XP or Vista. I mentioned a Mac because i had found instructions how to do it with a Mac.
    It seems that when I bridge the connections, it just kills everything until I un-bridge them. As I say, it has worked the other direction for me in the past which makes it all the more frustrating
  5. Draxin
    Draxin Seeker of Photons
    29 Nov 2001
    The bridging of the conections should allow for the two ports to communicate in both directions and it should not cause any problems with them functioning if they were functioning before the bridging.
    maybe try bridging then rebooting. Its windows, stupid things like that happen.
  6. Cupboard
    30 Jan 2007
    hmm... thanks.
    I think part of the problem may be the network I am trying to get it to "talk" to, though a friend has managed to get it working patchily.
  7. Firehed
    15 Feb 2004
    ICS has always been patchy at best in my experience, but that's what you need in order to accomplish this.
