Cooling Sharkoon Golf Ball or Air Penetrator
Discussion in 'Hardware' started by Bugste81, 4 May 2011.
  1. Bugste81
    Bugste81 Stephen
    16 Mar 2010
    I've got an Antec P180 case with the middle hard drive bay removed. In its place I've 2 Sharkoon 120mm fans one in front of the other. These are pointed at a GTX 480 which is overclocked and subsequently has its fan at a higher speed making it noisier. My question is would it be worth changing one of the Sharkoon fans for an Air Penetrator fan. Plus how what type of noise level do they create? I was thinking that if I replace one of the fans I could have it blowing straight up at the GTX 480's heatsink.
  2. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    I cant speak for the air penetrators as i dont have one. But saying that, you would almost definatley see an improvement.
    The sharkoons are awesome (i use them too) but they are not as 'aggressive' of an air shifter such as the AP's or the Sycthe GTs, but they are also nice and quiet :)
  3. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    APs are amazing. I'm using 3 in my FT02 and I have never found a better mover of air. Very quiet too.
  4. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    I've got two AP's arriving tomorrow for the front of my gaming rig so I'll be able to tell you tomorrow night or Friday night.
    I have a couple of 9.5v resistors coming as well, just in case.
  5. Oggyb
    Oggyb Mutant
    15 Jun 2010
    Why do you have one fan in front of the other? Directionality? Wouldn't a DIY funnel do the job better?
    You'd get better results putting that second fan in parallel if you can.
  6. law99
    law99 Custom User Title
    24 Sep 2009
    I'd consider the Sharkoon to be a very noisy fan. So personally I wouldn't be worrying about what the other ones are going to sound like. At least Fingers can tell you tomorrow though.
  7. Guest-16
    Guest-16 Guest
    APs are fantastic fans for directional airflow.
  8. Phalanx
    28 Apr 2010
    Or I can tell you now :) I'm using them as I type this! :)
  9. law99
    24 Sep 2009
    Oh yeah!!! :hehe:
    And can you hear yourself typing above the fans??? Apparently so!!
    They look an interesting proposition from bittechs own preview.
  10. Phalanx
    28 Apr 2010
    I can hear everything above them. They're quiet as anything.
  11. law99
    24 Sep 2009
    Cool. All I know is the sharkoon one I have sounds like the sort of fan we use at band practice... or less reputable people use as carbon filters.
  12. Bugste81
    Bugste81 Stephen
    16 Mar 2010
    Thanks. Think I'll order a couple this afternoon. Hang on the 120mm or 180mm?
  13. Fingers66
    30 Apr 2010
  14. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    how you finding them fingers?
  15. Fingers66
    30 Apr 2010
    I won't get to install them until at least tonight, maybe even tomorrow night. As soon as I do I'll post back here.
  16. Fingers66
    30 Apr 2010
    Okay, just done some unscientific load tests with the 120mm Air Penetrators replacing two 1450rpm Gentle Typhoons in the front of my Antec 300.
    By my reckoning, and taking into account an ambient increase in the room of 1C between multiple tests, the AP's have reduced my GPU temps (2 x GTX 460's in SLI) by around 2C-3C, depending on the test. They are slightly noisier than the Gentle Typhoon's - it is more a different kind of noise - but the case is right next to my head on the desk at the moment. If it was back under the desk I wouldn't be able to tell the difference.
    It is not a big difference in temperature really and could be accounted for by the unscientific nature of my tests.
    I'll see how it goes for a while then run the same tests with the Silent Eagle 1000rpm's and compare (tomorrow).
  17. [PUNK] crompers
    20 May 2008
    they certainly seem to push a lot of air for the RPM's, but you're right they have a distinctive tone
  18. Fingers66
    30 Apr 2010
    I've just run the same test but the the 9.5v resistors on the AP's. No difference in GPU temps compared to their full speed but a much more tolerable sound.
    I don't think there is a lot in it between these and the Gentle Typhoons. I'll compare them to the Silent Eagles tomorrow.
    The airflow with the AP's is certainly more directional but I am not sure it makes any difference in my Antec 300. I think the directional airflow would make more of a difference in a larger case - e,g, an FT02, ATCS840 or a big Lian Li and maybe a P180 like the OP's.
  19. [PUNK] crompers
    20 May 2008
    I think the key might be to have nothing in front of them (i.e HDD cage). They're certainly better than the lian li ref models anyways.
  20. bdigital
    10 Aug 2010
    Ive got the raven, but the one without the AP's..... I might have to get some
