Hardware Sharkoon T28 review
Discussion in 'Article Discussion' started by brumgrunt, 9 Jul 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. mikeyandrewb
    mikeyandrewb What's a Dremel?
    31 Oct 2011
    It can't really match the 100 in my opinion. Yes it has the USB3 port on the front and some cool features inside. I like the tool free bays and the bottom PSU fan slot.
    But aesthetically I don't really like it. It just looks flimsy and horrid. Maybe its just me but, I'd pick the 100 every time.
    Though I do have a 100 myself so maybe I'm not being fair....
  3. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    I love the blue. Why are there not more blue cases on the market?
  4. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    Quality of the case aside, it's not even the blue that I dislike, it's that it seems to be different shades of blue.
    Although this does touch on an issue I have been noticing for the last few years. Yes, you can still get silver cases but God forbid that you want to use any accessories with them. It is nearly impossible to buy a new optical drive in silver for example.
    However, as mush as cheap cases have come a long, long way over the last 3-5 years, as my case sits in full view and is going to be used to house a system of a few generations of updates, I do not begrudge paying an extra £100 to get the very best.
    I am yet to find a case that has appealed to me quite as much as the SilverStone Fortress FT-01 since I very first saw it what? 4-5 years ago? I love the look and quality of that case and the options it will give me for future builds. Although I will wait to see what the next case released from SilverStone is like and if they will release a USB3 version of the FT-01.
  5. MrTeal
    MrTeal Minimodder
    27 Aug 2010
    I might have bought an FT01 if it had an updated front panel.
  6. mikeyandrewb
    31 Oct 2011
    Maybe they should have interchangeable colours? Like a sheet of thin plastic you can change depending on the colour you desire?
    Now that would be cool...
  7. Jipa
    5 Feb 2004
    Oh gawd that looks cheap and nasty.
Tags: Add Tags
