News Sharp's Quick Release Screws
Discussion in 'Article Discussion' started by GreatOldOne, 2 Sep 2004.
  1. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    As befits our 'News of the Screws' monika, a sort of tech story that involves - yep you guessed it, Screws! :D
    But not any ordinary screws, according to Gizmodo:
    You're probably looking at that image on the right and thinking, "...uhh...." Well, I'd like everyone to know that I translated that image. Yes, I employed my superior Paint Shop Pro skills, took out the Japanese text, and replaced it with the English text that would fit in its place. And I did it without using any lens flares.
    This image was in Japanese because it's coming from Sharp, who has for some reason decided they don't really like screwdrivers. As part of Sharp's international "screw screws" campaign, they've developed some "Easy Release Screws," which when heated to 100 degrees Celsius (212 degrees Fahrenheit for normal people), will have a special washer section expand, allowing for easy removal of the screw, (if you're a robot with super-heated hands, of course).
    One of the primary applications of the screws will be appliances; recycling them requires dissasembly, which requires manual labor. With these new screws, machines could easily take apart a TV in a tenth (as Sharp estimates) of the time it takes a mere human.
    Link to the press release, along with the 'image on right' here
Tags: Add Tags
