Case Mod - In Progress Shazbom Waterworld 2 : Mod + Paint + New Build
Discussion in 'Project Logs' started by Shazbom, 16 Jul 2011.
  1. Shazbom
    Shazbom What's a Dremel?
    18 Jan 2009
    yep ketchup. Just leave it on any kind of copper for 2 mins and rub it with kitchen paper and you'll see the magic :rock:
  2. Shazbom
    18 Jan 2009
    going to install the blocks on the RE3 now. just took 2 pic of the RE3 to show you guys.
  3. jeckulz
    jeckulz What's a Dremel?
    18 Jan 2011
    I believe the active ingredient is vinegar?
  4. Shazbom
    18 Jan 2009
    Nah i dont think so. I tried pure vinegar but it didnt do anything.
    I put ketchup on it and the ketchup turned black after few mins, you dont even have to rub it.
    someone from dangerdan on their forum asked me to use ketchup lol
  5. Cheapskate
    13 May 2007
    You realize that you probably have ketchup under the plexi edge still, and the rig will smell like a hamburger when it heats up, right?:worried:
  6. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    probably was the whole idea... who doesnt love a hamburger??? mind you though it will make you hungry all the time smelling it. lol
  7. Shazbom
    18 Jan 2009
    @cheapskate. i'll take it apart and clean it from inside later. i was just testing the if ketchup would really work. i still have to clean the inside =)
    lol stem83 you're right. who dont want 1 burger while gaming.
  8. Shazbom
    18 Jan 2009
    Really pissed off again :duh:
    I've put all the parts together and guess what i seeeeeeeeeeeee. 4 to 5 big fingerprints under my plexi on the copper ram block. EK have a sticker on the side saying "void warranty if seal is broken. how am i supposed to clean it then. ahhhhhhhh..arhhhhhhhh..
    [​IMG] I want to ask them how they do their job. every block have fingerprints. arhhhhhhhhhh
    not only fingerprints. look on the left side there is 1 long ugly line on it. its not even coming out. i dont wanna use ketchup on a brand new block.:wallbash:
  9. amagriva
    amagriva Minimodder
    13 Jun 2009
    Fingerprints?
    send 'em to scotland yard, if they're :duh:not from Murdoch you'll know who is the guilty
  10. microsoftPerson
    microsoftPerson What's a Dremel?
    27 Dec 2010
    Can you run some rubbing alcohol, even diluted, through the block? I don't know much about watercooling, but if the alcohol won't destroy your block then it should be able to remove the fingerprints. The line/scratch is very visible in the photo, I'd request a replacement since its supposed to be new. Why don't they wear gloves when assembling these things?
  11. Shazbom
    18 Jan 2009
    @amagriva yeah what do you call them? i call them fingerprints..
    @microsoftperson thanks mate i tried but didnt help much..
    i had to use ketchup again and yeah it did the magic again..lol will show you few pic in a bit. my hands are still dirty from the ketchup. + yeah i wanna ask ek guys same question. i dont wanna send it back.. gonna take me ages to get another 1. i hope the ek guys are watching this ..=(
  12. Shazbom
    18 Jan 2009
    just finish cleaning the ek ram block.. check our the photos below.
    The more i look at it the more i think they sent me a usded copper block =(
    [​IMG] Now this makes me =), i wanna clean the motherboard block too lol.. but nah.. can't take it apart again now.. its on the motherboard already. =(
  13. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    Wow that is amazing. Some companies should put some ketchup packs, like the ones you get at McDonald's or so, with their blocks if you buy them. :D
    How did you find that out?
  14. Shazbom
    18 Jan 2009
    yeah everycompany should do that.. lol
    + i Googled it.
    Razer2007 likes this.
  15. mayhem
    mayhem Owner of Mayhems
    12 Sep 2008
    lol there is your answer pmsl.
    Contact me via contact forum with you address im going to send you some pre-mix.
    Tom ketchup contains acid that will effect the out come of any dye.... please make sure you rinse your system properly and use Bicarb if needed to get rid of it all ...
    KoSoVaR^ likes this.
  16. Shazbom
    18 Jan 2009
    Hi michael. Thanks. Ketchup did help clean my blocks but then it also left alot of acid on the blocks. Now whatever i put in my loop the color changes. =(
    Is there anyother easy way to fix this without taking the loops apart now? =(
  17. Shazbom
    18 Jan 2009
    For those who dont know what me and Michael are talking about.....
    i was in the middle of my build but things turn bad firt 1 of my gpu stop working. so now have to use only 1 4870x2 and now the color changes in loop.. no metter what dye i put it the loop, the color would change. i'll link a video i made for michael. The water in the loop is the same water i'm mixing in the video. once it goes in the loop the color change to purple :waah:
    http://www.youtube.com/watch?v=_1k_0UkjP1E
