shed loads of help, URGENTLY needed
Discussion in 'Hardware' started by Mother-Goose, 31 Aug 2004.
  1. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    oook so i removed the old motherboard and processor and put my new NF7-S with mobile XP2500 on it, and now it doesnt work.
    It wont boot into windows, it wont recognise the processor, it says un know CPU, i go into bios, and it cant find it, i cleared CMOS and it still doenst work, wtf do i do?
    HELP PLEASE!! :waah:
  2. Spiral Architect
    Spiral Architect Cooked on Phonics
    4 Sep 2003
    I think some people had that problem when using a certain beta BIOS. Have you flashed to a beta BIOS?
  3. Ben
    Ben What's a Dremel?
    11 Aug 2003
    you need to re-install windows. (motherboard chipset changed)
    the "un-know CPU" this happens with most xp-m's. As long as you can set the speed you will be fine if not you need to get a new bios.
  4. dead_man
    dead_man Confucious say: WTF???
    4 May 2004
    as the normal BIOS was never meant 2 support XP-M i think
  5. k3nn
    k3nn What's a Dremel?
    2 Feb 2004
    dont worry aobut the unknown cpu type, i was worried for a while, but it works with it, so dont let it bother you, if you can set the clocks to teh speed you want(think default for a 2500 is 166x11).
    definatly reinstall the os, cause the old drivers and crap wont work with chipset, should solve the problem.
  6. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
    I tried exactly the same thing when I upgraded from my old gigabyte board to a nice new NF7-S, its the drivers. Just reinstall windows and you'll be fine :hip:
  7. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    I think Ben may have the answer.
    What was your previous motherboard, did it have an nforce2 chipset, if not that is where your problem lies (I assume you are trying to BOOT into the same Windows install from your previous motherboard).
    If you change chipsets your Windows install will be setup for the previos mobo's driver set.
    You may be very lucky and get away with a repair install, if not the only remody is a complete fresh install of Windows.
  8. Mother-Goose
    22 Jul 2004
    ahhhh feck, yeh im trying to install on to a hdd with windows already on, and it wasnt the nForce 7 chipset.
    I did try and get it to bott from the windows CD but it wouldnt even do that, i was thinking for the repair u see. If i blanked a spare 40gb hdd i have, then install windows on to that then u think that should work?
    i only ask coz i dont wanna blank the 80gb one with all the stuff on thats in there atm becuase i need to back it up! hmmm
    and its just the standard bios in there atm, how would i upgrade that?...and actually, i will need to use another machine to format my drive wont i?
  9. Go4t
    Go4t i
    13 Dec 2003
    just install on the second drive and copy what you need over and then you can format the big hdd within windows
  10. Ben
    11 Aug 2003
    you can format on that pc in dos though.
    My method:
    1. Remove any other hard drives, other than the one to format. From the system (so you do not delete the one with all you work on it).
    2. Make or get a windows 98 boot disk (floppy) use this to get to the A:\
    3. Type fdisk in so it looks like this A:\fdisk
    4. Say yes (y) to the first question. then option 3. then option 1 (this will let you delete the primary boot partion)
    5. You then need to make a new one, so go back to the first set of options (esc key). option 1 will be create an new primary boot partion. in this one you want the partion to be the full size of the drive so say yes and fill in all the question.
    6. Then get back to the A:\ so repet step 1 & 2.
    7. Type format C: this will format the c drive and the prompt should look like this A:\format C: wate for it to compleat and then re-boot with out the floppy.
    i do not think you need the last 2 (6 & 7) for xp or 2000.
    or
    you could format the drive on another pc :)
    Ben
  11. Mother-Goose
    22 Jul 2004
    right, gonna have to do it on a partner PC becuase i dont have win 98 anywhere.
    and even before i do that, shouldnt i be bale to get into the repair thingy if iboot of the xp CD? coz it wont!
    tell u what, nothing is ever easy is it? lol oooh and i was wondering if u or anyone knew what would happen if i did the following:
    The mobo comes with and IDE to SATA adapter to plus one IDE drive into a SATA point on the mobo, it says make the drive a master, now what i wanna know is if a masta sata will override the master IDE? or if u can slave both IDE's?
    and another thing, the mobo has the standard big mobo strip plug socket and the small quad 12v socket, do i plug both leads in from the PSU?
  12. Ben
    11 Aug 2003
    You might need to change the boot order (in the bios) eg: 1:: floppy 2::cd-rom (dvd or what ever you have) 3:: hard drive.
    :confused: Pass don't know.
    Yes.
    Ben
  13. Mother-Goose
    22 Jul 2004
    coolies coolies, my boot order is CD-Rom, HHD0 and then HDD1, that right? i dont have a floppy drive
  14. Mother-Goose
    22 Jul 2004
    ok it doesnt work i get this black screen when its test the ports and pci stuff, put its in a table and put a num next to it then it says:
    CPU type unknown
    NTLDR is missing
    press ctrl + all+delete to restart
  15. Mother-Goose
    22 Jul 2004
    bump bumpity bumpity bump bump
  16. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    There have been 2 bannings/suspensions for (over) bumping recently.
    I suggest everyone takes note and does NOT bump in my forum.
    Thank you.
  17. Mother-Goose
    22 Jul 2004
    ok well then hows about HELP?
    it still wont work :waah:
  18. Xen0phobiak
    8 Aug 2002
    Use the fast repair wizard on the cd if you have xp pro. If not format and reinstall.
    Your thread has been floating around near the top of this forum since you posted it. You have no need to bump, any help you would have received you have had by now.
  19. Mother-Goose
    22 Jul 2004
    yeh soz, just paniky thats all. i formatted but i dont seem to be able to get it to boot from CD, at all, its weird, bios see's the drives there, even brands them, they open up as well so they are powered, im just confused, feel like im :wallbash: , know what i mean?
    oh and what are the settins i need to get my XP 2500 M barton running at stock speeds? i have it at 166x11, but its reading on start up as 1100Mhz
  20. Xen0phobiak
    8 Aug 2002
    Does it **try** to boot from cdrom?
