Modding Sheet Metal
Discussion in 'Modding' started by yoshima, 4 Nov 2010.
  1. yoshima
    yoshima What's a Dremel?
    4 Nov 2010
    Have recently decided to make a scratch build case, have almost finished designing it in sketch up and have started to look at suppliers for the materials I'll need, anyway to the point
    Looking at sheet aluminium is around 100 quid a decent price for 4 x 1 metre x 1 metre sheets?
  2. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    hi sry just to clear might be i just fin work :p is that 4nr sheets at 1m x 1m or 4mm 1m x 1m
  3. Boscoe
    Boscoe Electronics extraordinaire.
    5 Jan 2010
    Yep thats about wot your looking at for a half decent thickness, have a look at 'aluminium warhouse' it'll be a lot cheaper if you can get bgger sheets althoiugh this will cost a lot to post and they are down north of london so a bit of a drive for you.
  4. kinghong1970
    kinghong1970 Just a Clumsy Ape
    19 Apr 2009
    i swear... i know it looks like english but i have no clue what y'all saying up over there on the other side of the pond...
    :D
  5. yoshima
    4 Nov 2010
    thanks for the advice boscoe , will look around for local suplyers, already found 1 in liverpool ;)
