Modding Shiny New Paint Job
Discussion in 'Modding' started by nmmnp, 10 Jul 2003.
  1. nmmnp
    nmmnp What's a Dremel?
    19 Dec 2002
    Just finished buffing out my wifes new computer. I used Rustoleum Metallic...
    Here's what it looked like before I started.
    A shot of the inside and the top.
    And a few shots of the sides and front.
  2. JPLocutus
    JPLocutus What's a Dremel?
    16 Apr 2003
    Sweet paint job! :thumb:
    Colors make it obvious it's for a wife or other female companion though ;)
  3. KMS-oul
    KMS-oul You think you know me.
    1 Aug 2002
    Man you could prob use your case as a shaving mirror fantastic paint job and the colours work great together:thumb:
  4. Neogenesis
    Neogenesis What's a Dremel?
    4 Dec 2002
    how did you paint it? would you like to share your steps to us? mine has a mirror effect too but not like yours! lol would the color you choose to use make a difference in mirror effects?
  5. ernie
    ernie What's a Dremel?
    27 Jan 2003
    shiny indeed :thumb:
    i love the inside. can never get the inside to look as good as the outside for all my cases.
  6. overfloe
    overfloe What's a Dremel?
    17 May 2003
    marvelous paint jobbie :thumb: very professional
  7. Madyeti
    Madyeti Supermodder & sig shrinking victim
    1 Dec 2002
    A+ Work man! Great looking!
  8. MilitantB0b
    MilitantB0b What's a Dremel?
    8 Jul 2003
    Very Nice.:thumb:
  9. nmmnp
    19 Dec 2002
    Thanks everyone...
    Neogenesis - When I first started painting cases I followed the tutorial on PC-Workshop . I've since tweaked that a bit to suit my own style, but still follow the basic steps. I used all Rustoleum paint on this case, automotive primer, metallic spray and clear enamel. I'd say there's about 4-6 coats of paint and the same for the clear. Hard to say because I re-coat several times during the painting process and I paint an entire panel in 1 or 2 evenings (including the clear). I use 220/400/600 grit wet/dry for the prep work and 1000/1500/2000 (still looking for 3000 grit) for the finish sanding. Then it's 3m fine cut rubbing compund (which equals ~5000 grit), Meguiars #9 swirl remover (polish/cleaner), Meguiars #7 show car glaze (polish) and a whole lot of elbow grease.
    BTW - How come nobody asked what happened to the floppy drive opening ;)
  10. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    Oh yeah look at that, its been filled and painted.
    "What happened to the floppy drive opening ;)"?
  11. elneckio
    elneckio What's a Dremel?
    23 Mar 2003
    Excellent work.
    Wish I had that much patience when spraying things, I usually end with some random insect deciding that the thing I've just sprayed is the best place on the planet for him to sit and have a rest lol.
  12. Megavolt
    Megavolt What's a Dremel?
    4 Apr 2003
    You did such a good job on the floppy drive I did not notice it was gone. Great work!!!:thumb:
    BTW what did you fill it in with?
  13. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    yeah i want to know what u filled it with :D niiice paint job tho
  14. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    :jawdrop: :jawdrop:
    That is well nic ei love the way it shins :p its such a good job. now whats your secret :D
  15. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
    *floppy guess* bondo? :)
  16. Shuriken
    Shuriken same christmas AV for a whole year
    1 Jan 2003
    very very nice, one question tho.
    why do such a good paint job inside and have what seems to be a lighted fan, and no window?
    other than that, very nice job.
  17. 554
    554 What's a Dremel?
    22 Jun 2003
    can you paint my case :)
    I suxor at spraying
  18. tk421
    tk421 Idiot.
    15 Jan 2002
    wow ... and i thought my girlfriends case turned out good ...
    im going to go bask in my inadequecies now :/
  19. VadimtheConqueror
    VadimtheConqueror I love the little tacos...
    10 Jul 2002
    nice work on the paint, nice work on the filling of the floppy opening.
    i also wonder why the paint on the inside yet no window.
  20. death_star
    death_star What's a Dremel?
    14 Jul 2003
    Damn, that is shiney wish mine was like that. In that first pic it looks like the top of the case is invisible to the desk behind it.
