Windows Shotty Video
Discussion in 'Software' started by Ducarii, 5 May 2004.
  1. Ducarii
    Ducarii What's a Dremel?
    19 Feb 2004
    Well, some of my videos, a lot actually, play upside down, and are screwed up, like pixled sometimes, along with green overtone.
    I fixed this problem once along time ago, but I recently reformatted, I've got a tun of codecs: Real player, windows media player 9, Win amp, Xvid, DivX, and Kscodecv.
    Dose anyone know how to solve this problem of seemingly missing codecs?
  2. tk421
    tk421 Idiot.
    15 Jan 2002
    get ffdshow ... does xvid and divx, and lets you fix the video flip problem.
    its a side effect of having too many codec for divx iirc ... beware of super codec packs ... all most people need is ffdshow & a dvd codec ...
  3. Ducarii
    19 Feb 2004
    ah, ok thanks all get that now. :)
    Edit- Ok, I got it, and checked the flip video box, but no dice, its still upside down, do you think uninstalling my other codecs, then reinstalling just divX and ffdshow would work?
    Would make sence if what you say it true, that I have too many codecs. Or is there some other setting in ffdshow that could help me here?
  4. El_JimBob
    El_JimBob Minimodder
    28 Dec 2003
    He's absolutely right, matey :)
    However, dont let that stop u from getting Codec packs every so often - you never know when u might need an 'obscure' file to play a video :)
    I recommend the K-Lite one - it has a selectable installer so u can install only what u want to. Plus it has a FAQ that tells u what codecs have problems running with other ones....
  5. Ducarii
    19 Feb 2004
    Humm..I have K-light, I'll check out that faq, because thats where I'm having the flipped video problem for the most part.. actually thats the only place I'm having the problem, I just took out a vid file that was upside down in k-light, and played it in win-amp, right side up. Strange, thanks for the tips and help guys. :thumb:
  6. Ducarii
    19 Feb 2004
    Wow, so you need to pay for this k-light codec then huh? well screw that lol.
  7. Kermet
    Kermet [custom title]
    18 Feb 2003
    Not last time I got it, watch this space...
    EDIT - link
