Modding Should Filler Become Harder To Work With?
Discussion in 'Modding' started by bumfluff, 12 Nov 2006.
  1. bumfluff
    bumfluff What's a Dremel?
    18 Aug 2006
    Ok so I using Upol quick sand car bodyfiller and I have used it in small amounts three or four times and each time it has been harder to work with. Should this be happening? Could it be it has been at too lowa temperature too often, would sticking it on top of my aga for a few minutes help it? I have never used this stuff before, and dont really know how it should behave...
    It is the same as Bondo/P38
  2. Supra55
    Supra55 What's a Dremel?
    10 Oct 2006
    Did you mix the hardener with the whole batch or something? Or it might be you kept the can open to long and it hardend. After a week or so the bondo w/out the hardener will harden.
  3. bumfluff
    18 Aug 2006
    I am not that stupid :worried:
    The longest it may have been open is 5-10 minutes at a time. I am just sure it has become harder to work with/mix now.
