Storage Should I be worried?
Discussion in 'Hardware' started by Wira, 25 Aug 2011.
  1. Wira
    Wira Spoderman
    27 Jan 2011
    So I built myself a pc, it's been almost half a year now (I think).
    never had any problems until now windows suddenly tells me it needs to run a disc consistency check at boot. I let it and seems to mess with some files and finish, so no problems really.
    just, should I be worried?
    After googling it (yes, I did google it first), I found some people telling me it might be a sign of a bad HDD, especially if it comes up repeatedly.
    did take some pics with my camera (as I thought I might be in major ****, but I'm using it now just fine)
    thanks :thumb:
  2. Picky88
    Picky88 New Member
    18 Apr 2010
    It could be a hard disk issue, make sure you backup any crucial work NOW just in case. You want to run a hard disk tool that tells you about its SMART status, which is used to verify how well a hard drive is working. seatools is one I have used before. This error can also happen if you had a power cut or other disruption to the PC.
  3. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    You might run a full chkdsk /b as well to be sure.
    edit: Run from elevated cmd prompt.
  4. Wira
    Wira Spoderman
    27 Jan 2011
    hmm, use this pc mostly for gaming so wouldn't think I have anything especially important on here.
    I'll run the storage checks tomorrow.
    chkdsk is a windows command?
  5. Bede
    Bede Well-Known Member
    30 Sep 2007
    It checks for and (I think) can repair damaged sectors in hdds. Like lysol says, run it in admin mode - easiest way is start>cmd>ctrl+shift+enter.
  6. dark_avenger
    dark_avenger Well-Known Member
    9 Jul 2008
    Can just be a sign of a bad shutdown as well. Quite often happens with a power outage system will see a unclean filesystem and run chkdsk on the drive to make sure all is OK.
  7. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    BACKUP always BACKUP, even if the disk is fine BACKUP
  8. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    Can sometimes be sign of a disk going bad if happens repeatedly, or bad RAM, but generally it's pretty harmless and can happen if you got a crash, power outage or even just silent "bit rot". So doesn't even mean anything is necessarily wrong, Windows will sometimes run it as precaution after a bad shutdown.
    And The_Beast speaks wisely...
  9. Wira
    Wira Spoderman
    27 Jan 2011
    guess I'll have to get hold of a external HDD, just rly haven't got the money to spare :/
  10. The_Beast
    21 Apr 2007
    Fine the cash, I'd rather eat ramen for a month than lose all my data
  11. Picky88
    Picky88 New Member
    18 Apr 2010
    Save any data that you cant replace - including licences for any software/games you have paid good money for. You may only need to use a memory stick!
  12. Wira
    Wira Spoderman
    27 Jan 2011
    I rly don't know, guess I have a few photo albums on here, but it's nostly just games I have on steam or retail.
    Just had a wierd bootup where it took way too long for the desktop background/icons to appear.
  13. longweight
    7 May 2011
    Set up a drop box for 2gb of free online storage for anything vital as a temporary measure.
    Vagina boon - Peter Griffin
  14. Pliqu3011
    Pliqu3011 all flowers in time bend towards the sun
    8 Aug 2009
    I don't think it's a problem. Probably you've just promptly shut down your PC or something. That's what causes it for me at least. Don't worry about it.
    Backups are never a bad idea though.
    +1 for dropbox, it's awesome.
  15. MjFrosty
    MjFrosty New Member
    3 Aug 2011
    Let it check, if it occurs not long after it's probably failing, just make sure you backup, always!
  16. Wira
    Wira Spoderman
    27 Jan 2011
    it just did the chckdisk at boot again, I dont have anything very important on this computer anyway.
    maybe a fitting time to throw an SSD in there?
